Hp w2207 monitor keeps flashing
The quick view keeps flashing and scrolling up and down between settings and I can't see through it because it is in the middle of the screen
  • jjmaye Aug 21, 2008
    I habe the same problem but I have a dell dimension 4600 pc
  • 225 Answers
SOURCE: Vertical red line on HP w2207 monitor
Please try to connect the monitor to another PC, if problem still exist then probably there's an internal problem in the circuit board of your monitor wherein an elecronic part/s might be cold soldered / defective. I recommend to bring the monitor to an authorized HP service center to fix the problem. If the monitor display is good if connected to other PC, then your previous PC should be checked if the VGA card (if there is any) is properly placed to its slot & working properly as well as it cables & connections. regards
Posted on May 30, 2009
Lepcha
  • 25 Answers
SOURCE: hp w2207 monitor has no sound
Does the moniter have internal speakers? If so then there is a volume controller option on the moniter or else you have to use external speakers.
Posted on Jun 14, 2009
foxyreign
  • 52 Answers
SOURCE: Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
ted1430
  • 339 Answers
SOURCE: HP w2207 LCD monitor, the volume control window stays on
The volume button is stuck or defective. You can try massaging it around or spraying some contact cleaner in there but it's probably not worth the trouble since it's still under warranty and HP will replace it for you. Call 1-800-HP-INVENT and let them know what is going on and they'll take care of it for you.
They'll ship a replacement to you along with a return label to send yours back to them prepaid. You'll probably have it by the end of the week.
The OSD lockout won't help you in the meantime, the volume display won't come up but you'll get an OSD lockout nag instead.
Good luck, if you have any trouble filing a claim, let me know. We're an HP warranty center and can handle it for you as long as you get permission from Fixya first.(assuming you're in the US)
btw, this unit has a 3 year warranty and has been out only about 2.5 years so it's 100% that's it is still covered. Shouldn't be any issues regarding proof of purchase, etc.
Posted on Jul 28, 2009
Roonie Tunes
  • 136 Answers
SOURCE: my volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Posted on Sep 02, 2009
W2207 hp reset to factory settings
Do you want to know how to reset to factory settings or have you tried to?
Aug 22, 2012 | HP w2207 Monitor
Hp w2207 monitor randomly goes to sleep randomly, using windows xp
First make sure all the cables are securely plugged in. By randomly, do you mean a set amount of time of inactivity? Try this. If that doesn't work, it may be time to replace your graphics card (or buy one) or time to buy a new monitor.
Good luck.
Mar 07, 2011 | HP w2207 Monitor
The "Quick View" keeps popping up and there I
- I have this monitor before and already tried it to another system and it still doing it
- HP w2207 Monitor is known for this issue perhaps checking a stuck button on the monitor could fix the issue because the quick view feature is a built in feature in this monitor.
Nov 25, 2010 | HP w2207 Monitor
Hp w2207 wodescreen monitor menu keeps popping up. it is trying to lower the volume every few seconds.
check your screen refresh rate setting on 60 Hertz (Ctrl panel\display\setting\advance\monitor). or the OSD board was defective.
Mar 21, 2010 | HP Computers & Internet
Auto adjust in progress keeps flashing every 10 to 15 seconds , I have a HP w2207
my Aser 17" monitor model AL1706 i have some provlem my uper level one line
Nov 07, 2009 | HP f1905 19" Flat Panel LCD Monitor
My volume menu from monitor pops up, volume auto-decreases
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
May 29, 2009 | HP w2207 Monitor
My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Jan 14, 2009 | HP w2207 Monitor
View two different pages on two different monitors.
Sounds like you need to enable dual monitor in you display settings. There are three options there that will allow you to either 1. view one monitor at a time (sounds like your problem) 2. duplicate the same desktop on both monitors 3. expand desktop to the second monitor. (this is the one you want) On my Hpdv9000 it is accessible by right clicking on the desktop and selecting Nvidia Control Panel, -> Displays -> Multiple Displays. From here you can specify which monitor is your primary monitor where your start menu desktop will appear. But if you do not have an Nvidia Graphics card, which is typical of Hp's (your laptop's make you did not specify) this will be not much help sorry.
Dec 29, 2008 | HP w2207 Monitor
Computers & Internet Logo
424 people viewed this question
David Payne
David Payne
