Instructions Where do I get instructions for using the functions on this copier. Especially making darker copies
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
For making darker copies it will always be on top where all the functions are.
all copiers are different will have different access.
Posted on Aug 19, 2008
Mp 470 printer, how to make copies darker.
You most likely have done gradation simulation, strange that they are all light? All drums are new or in good %? have you changed out your transfer belt ITB?
Dec 04, 2013 | Canon imageRUNNER C3220 Color Copier
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Canon PC6re copier makes copies that are dark on the long edges
Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
Apr 20, 2009 | Canon PC170 Copier
Darker copies
GO ON LINE AND TYPE THE FOLLOWING INFORMATION.
CANON PC-150 GRAYSCALE COPIER SERVICE MANUAL AND DRIVERS
OR
CANON PC150 COPIER DRIVERS SERVICE GUIDE
CANONUSA.COM
IF A USERS GROUP FOR CANON FORUM
TRY TYPEING THE FOLLOWING:
CANON PRINTER USERS GROUP FORUM
ENTER
PICK FROM THE BEST OF WHAT YOU NEED IF ANYTHING.
ROD
Feb 09, 2009 | Canon PC-150 Grayscale Copier
We cannot seem to make a copy darker??
i would suggest that 1st you do the auto gradation adjustment full adjust under add function /adjustment cleaning then under additional functions look for one that says printer settings you can adjust black density under that setting
Sep 26, 2008 | Canon imageRUNNER C3220 Color Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
Modixerox 5510 functioning
Digital copiers will copy very light if the optics (mirrors, ccd lens) are dusty (opposite to the old analogue copiers which got darker) Clean whatever you can get at with a soft dry cloth.If it prints light from your computer then it won't be the optics, could be the ROS unit. If the ROS unit is dirty that's somewhat more complicated, the only bit you can get at is the ROS window, you'll have to pull the drum out and clean the glass window you can see from there
Jan 20, 2008 | Office Equipment & Supplies
Redish tone
This is because your printer heads needs to be cleaned or replaced! or either some particular colour is empty!
Nov 20, 2007 | Epson Stylus RX500 All-In-One InkJet...
k24674
