Question about Datamax DMX-I-4212 Label Printer
Printer Ribbon has a wrinkle in it
The Ribbon has a wrinkle in it and it is transfering to the label in a blank line whare the wrinkle crosses the printer head.
  • Datamax Master
  • 2,794 Answers
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Posted on Aug 19, 2008
SOURCE:
Intermec PX4i label printer. Paper/Ribbon loaded correctly, but ribbon is 'rippled' meaning barcode label being printed has white lines across it. Any ideas?
Ribbon Wrinkle as it called can be caused due to the main feed rollers (that touch the ribbon or the label) being slightly worn. Even if you have a sligh gradient on the roller(s) it will pull ever so slightly to one side. If you need the parts then please do not hesitate to contavct me. Jack Woodworth - Codeo UK, 01179064587
Oct 19, 2011 | Intermec PX4I Label Printer
I have z4mplus recently i changed print head , fonts are complete one blank line is same place for any priting
If the blank line is vertical (parallel to the print direction) then
Either the head is damaged at this point (dots missing) or you have something on the ribbon which prevents the head from doing the transfer.
Or the ribbon is faulty and you have to change the ribbon
Aug 11, 2011 | Zebra Z4Mplus Label Printer
Printer printed 5 tags but there is wrinkles in the tags so i tried to realign the ribbon and now it will not print
Ribbon wrinkles are due to:
- Ribbon too large.
- Print Head misaligned.
- To much heat.
- innapropriate Transfer film.
check with your tag dealer
Apr 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
Ribbon wrinkle
Its a bit of both. Too much pressure on the printhead can cause this as well as a poorly aligned ribbon. Adjust both then adjust the darkness the same as you would position or calibration
Jul 09, 2009 | Zebra 105Se Thermal Printer
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Mar 27, 2009 | Zebra Z4M Printer
Thermal Ribbon has a wrinkle
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Jun 03, 2008 | Datamax DMX-I-4212 Label Printer
Ribbon wrinkles when printing barcodes
This is usually caused by temperature of the thermal print head. This is found in the printing preferences of the printer.
May 22, 2008 | Zebra Z4Mplus Label Printer
Datamax DMX-I-4212 Label Printer Logo
720 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Johnathon Muise
Level 1 Expert
Joseph Mueller
Joseph Mueller
Pierre Legault
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
