I recommend that you get stronger hose barbs, the ones that thread into the pump where your hoses hook up. I can't see what you've got going on but, it sounds like the clamps may be crushing the barbs. If you can get, they make them, heavy duty plastic, maybe even brass barbs, they won't get crushed and, you can even double clamp your hoses to keep them from leaking. You may even want to go with a different kind of hose.
Hi decterhc,
All you need to do , use an "O" ring instead of the plumber's tape that you have added.
What has happened it seems that when you opened the filter to clean , you dropped these O shaped rubber rings which are to be placed at the mouth of the hose , this results in preventing any possible water leaks.
Please try to find out those O rings , if you have accidentally , unknowingly dropped it somewhere and then fix the hose again.
If a single O ring does now work , add another one and then it should stop any possible leakage.
Hope this helps ..:)
Hi decterhc,
Very happy to know that , hope it does not leak next time and if it does , you have the solution ready for you..:)
Hi Dexter,
I would like to inform you that there are certain liquids that you get in the market which function as sealants , so all yo need to do is to make a ring with that liquid and after some time it would become a rubber ring , you can use this in addition to the tape and this would stop any possible leaks.
Took apart yesterday, put back together. not leaking now.
Hose is about an 1"...screw clamps
I have no idea the cause!!!
This one is brand new...did not drop the O ring. and FYI...no one carries the O ring....and TETRA has not had any for 3 months.
Thanks for that suggestion....it ran great for 5 days, no leaking at all. Got up yesterday and the pond was almost empty. Was fine at 9 pm the night before. Looks like it is leaking from the clamps. I opened it and put white plumbers tape around the o ring area. Held for about an hour...now is leaking again, not as bad. Thought I'd add MORE tape today.
The o ring from the old unit is larger than the o ring for the new unit. NO ONE HAS THE O RINGS>>>>>>NOT EVEN TETRA!!!!
Can you give me a name of that liquid???
