Question about ASUS F3SV-B2 Notebook
Resource file not found
This message show that system require the file C-SpURsDll
  • Glou8366 Nov 14, 2008
    Same problem on a ASUS F7SR fitted with Vista home after running a registry cleaning sesssion (with JV16 powertools).
    Best regards
Corrupt software
Try uninstalling and then reinstalling the application in question. If that does not resolve the issue, try installing the software in another computer. If it works there, then the issue lies with your operating system in your original computer.
Jun 17, 2017 | Computers & Internet
Not found file C-SpURsDll
This is a registry issue a cleaner wiped the file good idea when using a registry cleaning program to back up the registry before cleaning. This way if you run into this again all you have to do is go to the backup and restore the registry edit you did.
Also if you have a motherboard disc re-install the mother software again. This should solve the issue for you.
Apr 21, 2012 | Computers & Internet
Lost computer programs require reinstallation with restoration files. Where the restoration file had been made as backup media is simply acquired to resplace the missing entities. Usually the computer program loss is capable of least replacement because was unpredictable without prior backup restoration files available. Once experienced program losses either with situation of prior anticiaption of compromises or least expectation praparations, computer restoration alternative is resorted. A lost computer operating system would have compromise the entire programs either as stored to volatile memory. Alternately loosign program fragments least compromises the computer system. Usually, computer data losses compromises the users resources though still remaining is a functioning system capable of reacquirng data resources. computer Losses are unexpected accounts either as user data or systems program functionalities that contribute towards resorucesfullness. A computer loss requires evaluation to ascertain the extent to compromise from which determinations are made for reestablishments. The conditions of the computer resource loss would require evaluation as precautionary measure also required. The evaluation phase of computer losses may likely be computer systems related least human resource generated with an alternate arrangement for replenishment altogether. Alternately, the computer loss usually affects resource productivity requires reestablishing the situation. An evaluation of the conditons to reestablish restoration once feasible to attain restoration should be commenced. Aternatively, the reevalaution would produced results comprosign the contribuion ot resourcefulness. Altogether, computer losses have resolution mechanisms as improvment over the prori conditions. Consult with computer systems analyst to acquire the setup structure that replaces the prior to attain better integrity.
Jan 26, 2011 | Computers & Internet
I have a Logitech quickcam E 2500. When making Video calls the picture freezes. Sound continues fine
This is a system resource problem.
Do the following maintenance on your computer to see if it is a simple resource problem or requires more complicated cleanup.
Use the Windows Disk Cleanup Tools:
  1. Click Start, Run and type cleanmgr.exe
  2. Click OK after the dialog box pops up with all of the items it wants to clean checked off.
  3. Do not run or click the option to Compress files
  1. Check your available disk space - Right click on the My Computer icon and select properties. The graph that comes on the screen should show more than 15% in pink.
  2. Run Defrag.exe from the accessories, system tools menu
If these simple things do not correct the problem your system will require a more complicated cleanup. Comment back if this is the case.
Apr 29, 2010 | Logitech Webcam
Receive cant find SIERA.err when i try to open my hoyle classic games
found this on the sierra support site, this was for king's quest, however it should resolve your issue as well ..
Problem: "Windows title not found" error when starting game, followed by "Cannot find SIERRA.ERR". (Windows 3.1 and Windows 95)
Solution: These error messages are caused by a corrupted or incorrect RESOURCE.WIN file. The RESOURCE.WIN is a small text file that contains information aout your computer. The game program looks at this file to determine where the game is installed and where to look for the game CD. If this file is missing information, you will get the above error messages. To correct this, edit the RESOURCE.WIN file (it's in the game directory!) and check that the first three lines look like this:
title=King's Quest VII
If these two lines are missing or show different information, add them or change them to match the ones above. Remember, they must be the first three lines in the file. Then, check that the last five lines look like this:
These lines assume that King's Quest VII is installed to C: and that your CD ROM drive is D:. If your drive letters are different, make the appropriate substitutions. If these five lines are missing or show different information, add them or change them to match the ones above.
You should also check that the King's Quest VII icon's properties indicate the correct working directory. To do this, click once on the King's Quest VII icon to highlight it. Then press ALT-ENTER (Windows 3.1) or right click (Windows 95) to access the icon's properties. The command line should read:
The working directory should be your CD ROM drive, for example, D:\. If your CD ROM drive is another letter, substitute the appropriate letter. Click on OK when the working directory is correct.
lemme know if the issue was resolved..
Dec 03, 2009 | Video Game Consoles & Games
My yahoo messenger when opened says "cannot load resource DLL"
The error message indicates your operating system is not able to load one of the files required for Yahoo messenger to work.
To make sure Yahoo messenger is installed properly, download the installation files and save them to your desktop.
Once you have the installation file...
Open the control panel and uninstall the existing version of Yahoo messenger. This will remove the program from your computer and clear out the registry entries that were created during the first install of Yahoo messenger.
Reboot your pc and then run the Yahoo messenger installation file you downloaded to your desktop.
The system reboot is a precautionary measure to ensure that none of the files used by Yahoo messenger are loaded into memory during the reinstall.
Sep 08, 2009 | Yahoo Messenger
Ressource files<C_SpURsDll>not found
Dec 16, 2008 | Computers & Internet
Editing text
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Error Contacting Update web service
I don't know what program you're using, but usually when you get the message "An error message cannot be displayed because an optional resource assembly containing it cannot be found", it is because the program is using the .net compact framework but the file has not bee installed on the device yet. That .cab installs the resource file that is missing. Once it is installed on the device, you'll see a better error message than the one you're seeing now.
Brad Radaker
Radicomm (maker of QuickTalk - push-to-talk for the MC9090)
May 07, 2008 | Zebra Symbol Technologies MC909X-G Series...
ASUS F3SV-B2 Notebook Logo
703 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
