What may not be obvious is the fact that the WHOLE assembly gets removed, in order to replace the bulb. DO NOT touch the glass of the new bulb, or suffer really short life. There are usually 3 or 4 NON ADJUSTING screws that hold the entire assembly in place, Release those, pull the unit out and you can easily change the light.
HEADLIGHTS NOT WORKING
It
can be faulty headlight switch or issue with its wiring. Or its faulty head
light fuse.
To
troubleshoot the issue i suggest you few help links with appropriate solution.
So you can follow the test and confirm what exact problem is there in your case
of headlights not working:-----
Click
the link below: -----
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car
headlight bulbs don't last long?
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These
will help.
Thanks.
How to Replace a
Headlight Switch
Low beam headlights Modification?
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a
Headlight Door
All headlights not working?
How to replace HID headlight bulbs for lexus
400h?
• Car headlight bulbs don't last long?
These will help.
Thanks.
http://howtobyme.blogspot.com/2011/11/only-high-beams-work-but-head-lights.html
Only high beams working on GMC Savana?----------
High beams stopped working but headlights still
work?
http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
• Working of Headlight switch? ----------
• Both headlight bulbs blow together? ----------
Only one head light works on 2001 Dodge
Caravan?
http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
these will help.
Thanks.
