Question about Lands Phones
Directory Programming How do I program names & numbers into an NEC Dterm 80 corded phone?
  • Anonymous Feb 27, 2009
    Ho do I change numbers in the directory?
  • Anonymous Apr 09, 2009
    WE NEED TO PROGRAM VENDERS PHONE NUMBERS IN TO
    THE DIRECTORY AND CAN NOT FIND THE USER GUIDE FOR THE
    D TERM 80
I have the same problem
Posted on Nov 11, 2008
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
I have a NEC Dterm 80 phone system in our office. Not all phones will ring when there is an incoming call, and I want to set them ALL so that they will
Dterm 80 works on several systems, would be helpful if you mention what system you have. Programming lines directly onto a phone is done in system programming, not really something you can do yourself. If your IT person has the programming software, great. Very rare someone on site is tasked with knowing the phone system at that level, because it gets deep quick, and your working on the whole thing, not just one phone.
Jun 23, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How to change name on nec dterm 80
You need to do this from the Admin phones, by default the lowest ext #'s on the system.
This is system programming not the phone itself.
Refer to the Attendant guide for the phone system model your phones run on.
Nov 01, 2012 | NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571...
Our phone is a NEC DTerm 80, but looks a lot like ...
The Display can be swapped.... if you can find one.
Otherwise no programming is retained in the telephone. Swapping phones will not loose any data programed to that jack/Extension number
May 21, 2010 | NEC DTH-8D-1 Corded Phone
I need to change my display name for my Dterm 80 phone. I also need to add a name and extension
you need to access program mode on the phones.
mb 4-18 is name assignment
new station is 4-10
ldtsnj.com
May 11, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I have a 4 line NEC Dterm 80 phone. How do I recall the past
depends on the type pf system. Do you have a coib installed in the system? Is caller id setup or programmed? If there is no mif card in the switch you cannot save caller id info. It only shows up when the phone rings and while on the call. There should be a directory key that you can price to scroll through the numbers if everything above is correct. ldtsnj.com
Dec 31, 2008 | NEC DTU 8D-2 Corded Phone
I WANT TO TRANFER CALLS TO MY CELL NEC DTERM 80
speaker 47,9+1+area code and number....beepbeepbeep hang up.
Nov 13, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Have NEC D term 80 phone without manual
The manual is here.
NEC doesn't call it the "Dterm 80 manual," but that's it. It's titled "Electra Elite IPK II Multiline Telephone User Guide."
May 02, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTerm 80
Try dialing the numbers 725 and then hang up...to turn it off..same thing. Ours works this way at work.
Apr 02, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTERM 80 Call to speakerphone
While the station is ringing - Press "1"
The feature must be enable in programming to be active.
Mar 06, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
266 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
