I have a Stanton T-80 turntable which when i switch on the platter does not move. Everything is swtiched on but still wont budge. It did go a little slow last time I used it. What do you advise?
  • inkokiko Aug 19, 2008
    Hi
    Thanks for the reply
    It's a direct drive unit.
    Power is fine, its simply the plater wont move. If i assist it, I moves slowly for about 2 seconds then stops.
  • 979 Answers
Is this a belt drive unit? Seems to me that this model was. It might just be a slipping belt....accordianman
Posted on Aug 19, 2008
Str8 80
and now your question with most details as possible pls. This ain't a question, only that are may beca switch under your platter, well four feet.
Mar 10, 2014 | Stanton Audio Players & Recorders
Stanton str8 80 wont spin anymore
Remove the platter and check the drive belt is fitted correctly. Keep em spinnin, John. Stylus City.
Feb 27, 2014 | Stanton STR8-80 Turntable
How to fix a wobbly turntable stanton T.50
Check if the platter is oke and aint stock, and otherwise is you spindle bearing defect.... A platter ain't goes from flat to wobble all of a sudden. And try to get the stuf second hand, or better, buy a better unit, not from stanton, but a refurbished 1200mk from technics is ok, if you sprin records. If you only listen, take a loke at the rega and pro-ject sites.....
Jan 01, 2014 | Stanton T.50 Turntable
Remove platter stanton
I know the problem, don't going pulling hard. Give a little knock with a small hammer en voila, the platter is loose. If not, let somebody
pull the platter and give a knock on the spindle(first use a bit thin oil from above, non aggressive, bike chain lubricantoil is perfect) and then it's easy. But pulling has no use, While a hammer does wonders.
Succes, richard
Oct 13, 2013 | Stanton STR8-100 Turntable
Stanton t.80 Motor produces hum sound when holding the platter to cue. When platter is released the hum disappears. Also is a slight hum on start up. Have opened the turntable and all connections seem to...
Do you keep the platter at one place --> don't you let the platter spin and keep the record at. one place, you are know f.5;5,g your engine and parts.... buy suzuki slipmats and use the plastic rounds of plastic .... i thought by thud rumble too let your table spin when you hold the the platter, otherwise components get to hot
Aug 03, 2013 | Stanton Audio Players & Recorders
At-pl120 getting power from cord, hear on/off switch clicking, opened witnessed contact move, yet no power, zip nothing? any ideas, isaw no fuse inside near power inlet thanks need ansswer asap so i can...
is this belt or direct drive. if its belt try replacing the belt if its direct drive and your hearing it turn on and the platter doesnt budge when you press start the motors blown. I hope This helps, by a Stanton next time not the expensive ones just a nice direct drive table .
May 14, 2011 | Audio Technica AT-PL120 Turntable
Platter wont spin on stanton t 120, all the lights turn on fine, platter seems to feel jammed, it wont spin easily when i push it by hand.
The belt that drives the platter may have shifter or the gears that turn the platter may be unaligned. Open it up yourself and check out the inside but be careful not to break anything or go into a local music/dj store. they may be able to help you for cheap or for free.
Mar 02, 2011 | Stanton T.120 Turntable
Turntable will slow down for a moment while playing causing a dragging effect in the sound of the record. Turntable hasn't been dropped or damaged in any way.
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Sep 28, 2009 | Stanton STR8-80 Turntable
Mid 70's sears turntable. plate will not spin.
take a soldiering iron and touch it to the metal in the center of the platter for a few seconds. this will heat up the grease on the inside and allow the platter to budge. should work fine afterwards. what happens is over time the grease hardens and locks everything up. applying some heat will loosen things up and get it running again
Jun 09, 2009 | Audio Players & Recorders
Belt fell off my stanton turntables, so it will not spin
Ok, so put it back on.
It's very simple, just take the platter off, and out the belt on the bottom. Then put the platter back on, and you'll have to pinch the belt off the platter, and wrap it around the motor shaft.
- Davis
DJ Pro Audio
www.djproaudio.com
Jul 14, 2008 | Stanton STR8-50 Turntable
 Grubhead
Grubhead
