Memorex pocketvision-26
Unit has sound but no vision, with new batts.
  • dennisbcoone Aug 26, 2008
    Power relay is intetrmittint
What batteries go in this unit how many 12? need a replacement
8.3 Battery Configurations
There are different configurations for different battery types and backup time. Here, the batteries from VISION and
YUASA are selected. The backup times ranges from 1hours to 4hours for 20KVA UPS and from 1hours to 2hours
for 30KVA UPS, because of limitation of CLA power rating.
UPS Backup
time Number of blocks Type of blocks Capacity(10H)
1h 1×24 6FM55SGX 52Ah
10kVA 2h 2×24 6FM45X 2×42Ah
4h 2×25 6FM75X 2×74.5Ah
1h 24 6FM75X 74.5Ah
15kVA 2h 3×24 6FM45X 3×42Ah
4h 3×25 6FM75X 3×74.5Ah
1h 1×25 6FM90X 90Ah
20kVA 2h 3×25 6FM55X 3×52Ah
4h 2×26 6FM150X 2×144h
1h 2×25 6FM75X 2×74.5Ah
30kVA
2h 3×24 6FM100X 3×96Ah
Sheet. 4 the battery configuration with VISION battery
UPS Backup time Number of
(10H)
1h 2X24 NPL24-12 2X24AH
10kVA 2h 2×26 NPL38-12 2×35.3AH
4h 2×26 NPL65-12 2×60.5Ah
1h 1×27 NPL65-12 60.5Ah
15kVA 2h 2×24 NPL65-12 2×60.5Ah
4h 3×26 NPL65-12 3×60.5Ah
1h 1×27 NPL100-12 92Ah
20kVA 2h 2×24 NPL100-12 2×92Ah
4h 4×26 NPL65-12 4×60.5h
1h 3X24 NPL65-12 3×60.5Ah
30kVA
Mar 30, 2014 | MGE Galaxy 3000 UPS System
Installed new batteries and the unit will not power up. Check polarity and everyting is correct.
Hello, there really nothing I can tell you until I get some clarification on you Bushnell NV audio amp. If it is new then send it back. Did you fill out your warranty card? Also, since they call it a audio scope 26-300 do you need to use ear phones with it? GB...stewbison
Aug 24, 2011 | Bushnell 2.5x42 Night Vision Audio Scope...
My memorex quit playing all sound
  1. Unplug the unit and remove the batteries, wait 5 minutes, plug the unit back in and install the batteries.
  2. Check the male end on the iwake and the female end of the ipod for damage, if you are using an ipod it sounds like you may have a bad connection.
  3. Check if the Radio function plays sound.
  4. Make sure the Volume is not turned down.
  5. Does it play through the headphone jack? If so, your speakers may have failed.
  6. Most likely this will need to be sent in to Memorex, or a new unit will need to be purchased.
Contact Memorex product support, please call 1-877-363-6673 Monday - Friday: noon to 9:00pm, EST
Feb 25, 2011 | Memorex iWake MI4004 Clock Radio
My remote no longer works power on/off or volume on my LG 50 PC 30 plana flat screen. New batts, no obstructions. Help!?
Assuming the batteries are good and installed properly, you can view the Infrared output of the remote with any video camera that has night-vision mode.
Goto a camera shop with video cameras on display, set the unit to nightshot/night vision, and look at the front of the remote while pushing the buttons. You should see flashing from the unit, as the infrared LEDs are very bright.
If you see no flashing, then you likely will need to purchase a replacement remote.
Oct 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Hi the ir is not working on my bushnell 26-0400,is there any way you can help (repair ?)
I had the same model, same problem. Bushnell replaced mine under warranty, If they needed to send it for repair it had to go to Russia. I guess it was cheaper to give me a new one. If its not under warranty Bushnell will send it off for you but it will cost quite a bit. My new pair lasted about 2 years with a lot of usage. Gen 1 night vision tubes do not have a very long life span. You may be better served buying a new pair of night vision binos.
Jul 08, 2009 | Bushnell 26-0400 Binocular
Does anybody know what type of battery The ITT night quest 220 ni
I'm pretty sure that your unit uses the 3V cr123 Lithium battery. You can get it at RadioShack. You can always take it down to radioshack and pretty quick you will find the correct batt.for the unit. Do not use rechargeable batts!
Mar 13, 2009 | ITT Night Quest 220
Remove battery cable and car dies. got a new battery & alternator
y are you taking the batt cable off does batt go dead if you use car let me know
Feb 18, 2009 | 1996 Eagle Vision
I hae a memorex 6142u w/ no vista drivers???
Go to site http://support.visioneer.com/products/home/EOL/Memorex/
Download/save application file 6142. Check file properties, under compatibility select "run this program..." and choose Windows XP(Service Pack 2). if u do not have a vista option
Then run the program.
Good Luck
Jan 26, 2009 | Memorex MEM48U Flatbed Scanner
Memorex HDTV no picture
I am going to assume that you have not already found the answer to this problem. It is actually pretty common for flat panel televisions in the winter to be too cold to turn on. What I did when faced with this problem on my 32 inch memorex was turn it on for 30 minutes while covered with a fleece blanket, than turn it off. When you turn it back on it should work...did for me!
Dec 31, 2008 | Memorex MLTD2622 26 in. LCD TV
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
