Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome 9000 First, while sewing, thread tangled up on backside of fabric and machine stopped. I untangled the mess and started to sew again and same thing happened.. then the machine "died". After reading here how to find and replace fuses, I did that. (Radio shack didn't have a 3.0 amp so recommended I use 3.15 amp.. was that OK?) Machine was back in business, however the tangle problem was still there and the machine died again. Now I need to replace the fuse again.. but could my tangle be due to the hook race?? I have cleaned everything of lint, etc. and notice just a teeny sharp protrubance in the curve of the thread catcher.. is it supposed to be there or do I have needle damage to it? I once used fine sandpaper to smooth the needle marks on the faceplace of my old Kenmore.. could this be the problem?
  • Gail Bender Aug 26, 2008
    It was, in fact, the bobbin tension.
    It's fixed and running great.. the fuse issue was unrelated.
    Thanks!
The heavy "knitting" on the backside of the fabric sounds like a tension issue due to your thread catcher or other. You may want to look at this link:
http://reviews.ebay.com/SEWING-MACHINE-COMMON-TROUBLES-HELPFUL-HINTS_W0QQugidZ10000000007548289
The fuse issue may very well be unrelated, just coincidental.
Posted on Aug 26, 2008
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
The bobbin thread keeps getting all tangled. i have cleaned it all out several times but when i start sewing again it does it again...what am i doing wrong?
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the bobbin is turned the right way inside the case
make sure the thread has not come off the thread take up lever,
if it has, try putting some tape over the thread take up lever, but
make sure to leave a whole to get the thread thru
Jul 27, 2012 | Janome Memory Craft 9000 Computerized...
My machine janome 9000 acts like it wants to sew then it stops and locks up I have checked the bobbin thread and it is not stuck
then something is either worn or broken in the mechanical part of the machine or a part of the computer is messed up,, it needs to be serviced
Feb 28, 2012 | Janome Memory Craft 9000 Computerized...
I attached the walking foot , but the needle will sew through the fabric
this is what my instruction book says
Lo---a button is pressed when the machine halts due to overload
wait for at least 15 seconds to recover
if thread jamming causes overload, remove the tangled threads
Jan 17, 2012 | Janome Memory Craft 9000 Computerized...
Thread is going on cutting.
you do need to provide more details.  start here - get a fresh spool of high quality all purpose thread such as Coats and Clarks or Metrosene thread, fill a fresh bobbin, install a new size 11 needle.  Follow the threading instructions even if you've threaded the machine a million times, read the instructions again.  try sewing on some basic cotton fabric.  You'll be able to determine if it's the machine.  Breaking thread can be the thread (it does get too old and fragile), the needle, the incorrect needle for the fabric, the wrong thread for the fabric, and a host of other things.  So try that and tell us more if that doesn't work.
Dec 27, 2008 | Janome Memory Craft 9000 Computerized...
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Apr 30, 2008 | Janome Memory Craft 9000 Computerized...
White thread keeps pulling through
Manual for Janome 9000 is available from the Janome site. http://www.janome.com/documents/File/ManualFile/inst%20book%20MC9000.pdf
Aug 31, 2007 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
138 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
