Question about Intuit QuickBooks: Pro 2005 for PC
Help I am the Treasurer for a small church. I work with QB 2005 but it keep giving me a message when I open it that it needs to be upgraded and I only have a few more times to use it until it won't work. We don't have the money to upgrade. Is there any way to just keep using what I have? Please advise.
  • scottdseely Aug 19, 2008
    How can I keep using QB2005 without having to upgrade or keep registering?
    Champion:
  • Intuit Expert
  • 237 Answers
Intuit designed the QuickBooks software to run for 30 days without a registration number, or Validation code as they are now called. It was designed to operate as a trial period. At 30 days, the options were to purchase the program, which granted you the code number, or the program would stop.
Once registered, the program should operate without the need to re-register unless it was reinstalled, or the registry entries were damaged, and therefor, lost.
I fully understand the monetary constraints you are facing. I also understand that Intuit only supports the 3 most recent versions ( 2006,2007,2008) as trying to keep older versions updated is not really cost effective.
If your program keeps losing the registration numbers, you have something on the system that is damaging the locations where that info is stored, like the registry. As for continuing to use it without registering.....that is simply not an option.
Posted on Sep 15, 2008
I can't reinstall my Pro 2005 because it asks for Flash 7 then the cd tells me it can't install it.
You're several versions behind with your QB Pro, and also several versions behind with the Flash Player you're trying to install.
If you're reinstalling because you upgraded your operating system version, this is likely the root cause. QB 2005 is not compatible with Windows 7; neither is Flash 7.
While you may be able to install the program using XP Mode, that isn't the most reliable way of running it. I recommend avoiding uninstalling the .net framework files and "back versioning" as a way of getting around it, because it is likely to cause problems with other functions.
You may be best off to upgrade your Quickbooks version.
Hope that's helpful.
Jan 16, 2011 | Intuit QuickBooks: Pro 2005 for PC
Error 7149 Quickbooks
Thanks, that worked! I first spent a half-hour on the phone with the non-tech support at Intuit and he walked me through that download. What the download does is update your original QB 2005 RC1 version to the RC9 version ("Release Candidate") where they've fixed some things (such as the Flash 7 install problem). Here's what we did:
1.) Removed Flash ActiveX 9 in Add/Remove Programs
2.) Downloaded webpatch from QB site (start here: http://www.quickbooks.com/Help...
3.) Closed QB (couldn't open it anyway)
4.) Installed patch.
5.) Restarted computer.
6.) QB worked!
Thanks for your postings. I hope this helps.
Thanks.
May 07, 2010 | Intuit QuickBooks: Pro 2005 for PC
QB pro 2005 and Internet Explorer 8
As with all evolving software (as the well written ones are), as you update one you'll invariable need to update others. If you want QB Pro 2005 to work properly, you'll have to contact Intuit for any patches to their software to make it compatible with IE8. I suspect that Intuit would rather sell you an upgrade to their most recent version of QB Pro (hence lightening your wallet substantially). If there's functionality in IE8 that you absolutely HAVE to have, you'll probably be stuck paying for the QB Pro upgrade. Otherwise, you can simply stick with IE6 or 7 (as you've already reverted back to). Sorry there's not a better answer.
Aug 13, 2009 | Intuit QuickBooks: Pro 2005 for PC
I HAVE QB PRO 2005. I BOUGHT A NEW SYSTEM WITH
Try the latest Adobe flash player here >>>>>>>>>>>>>>>>>
http://get.adobe.com/flashplayer/
You shouldn't have to reboot but i would to be safe then try to install Quick Books again.
Good luck.
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
May 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
1)I can not install my update of Quickbooks Pro 2005. Get error message "File ComponentsHelpCacheqbhelp.qcd can not be located" What does this mean and how do I correct it? + 2)When clicking on the help...
Assuming you have the install files for QB 2005, reinstall it with the original parameters and then un-install it. The missing file is stopping the un-install, and assuming that you cannot edit the uninstall parameters, about the only way to actually uninstall is to make sure the 2005 install is complete before you unload it.
Apr 19, 2009 | Intuit QuickBooks: Pro 2005 for PC
Can't open company file after upgrade
This is not a quickfix, but I had the same problem going from QB Enterprise 2005 to 2009. I found someone who had 2008 and he restored my 2005 QBB successfully - it prompted him for a password. He then made a backup as a 2008 QBB which I restored on my 2009 - it prompted for a password as well. Hope this helps.
Jan 22, 2009 | Intuit QuickBooks: Pro 2005 for PC
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
Problem when installing
In order to understand where the issue lies, I would need some additional info, such as the Qb version, the version of Windows etc.
Sep 15, 2008 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks pro 2005
I got this solution off the official site forums. This worked for me hope it does the same for you guys.
"Thanks for the post. Let me start by apologizing for this. We had sent out a message concerning IE7 and QuickBooks. What is going on is a dialog box is trying to load, but it is not loading completely. Windows is waiting for a response from this dialog box, that can't be seen. What we should be able to do to work around this for now is to press Alt-F4 at the same time. This should force this window that has not loaded correctly to close. Now we should be able to work in QuickBooks without any trouble. If this does not work we may want to hold the CTRL key down while double clicking on the QuickBooks Icon. The first solution I have seen not work only once."
Jan 14, 2008 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks: Pro 2005 for PC Logo
216 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
