Question about Nokia N91 Cellular Phone
Theme installation problem
The themes whichever i download are not installing
    Problem Solver:
  • 5 Answers
Firstly, go to your clock and than change the date to 2007 and month of april,may,june depends on the software made date
Posted on Oct 17, 2008
SOURCE:
How to download themes via 6600
nokia 6680 nokia's first 3g phone.
your phone belongs to s60v2 series and supports .sis extension type themes.just try the following procedure to download theme via phone it self.
  • just visit the site www.mobile9.com or www.ownskin.com through your mobile(use operamini or ucweb or default browser).
  • find download section of theme for nokia 6680.
  • download theme you like most.it should be in sis format.
  • when downloading finished open it.
  • it will ask you for installation.install it on memory card.
  • to apply theme you downloaded go to tools then in theme.
theme you downloaded must be there apply it.
now you are done.ALWAYS USE FIXYA TO FIX YOUR PROBLEM.
Feb 16, 2011 | Nokia 6680 Cellular Phone
Tip
Changing themes on Windows XP.
So, here we have a simple guide on how to change your normal windows look and how to install a custom theme which you will find many online.
Here is our original windows xp themed start menu and desktop.
First to install a new theme you first have to obtain one, here are a few
After you have downloaded the zip file containing the theme. Double click on the file to open it.
Now, this may look different on your pc, it depends if you have installed a program to extract zip files. If you are familiar with zip files etc just extract the files and run the setup to install the theme.
Inside the zip file you will find the following
Double click on the setup file to install the theme.
you may get a pop-up asking for you to extract all, run or cancel, click on run if you do. if asked again, click run again.
Basically install the theme just by clicking next next next and finally finish.
Once you have installed the theme, right click on your desktop background and select properties.
On the properties / theme page, click open the list of themes and select Royale from the list, then apply and OK.
And here is the new theme we downloaded:
You can obtain different themes from all over the net, I would suggest you go with the site linked here, scan the files for viruses before installing. Good luck and thanks for reading.
on Jan 23, 2010 | Computers & Internet
Can i get themes through computer?
You can try downloading a piece of software called EFS Media Builder. This software allows you to browse and delete protected directories on your Viewty.
Note: if you use this software you could delete or move crucial files which will render your Viewty inoperable. Follow the instructions we link to carefully and ensure that you have a backup of the phone's firmware
To install a new theme you will need to use EFS Builder to copy it across from your PC and overwriting the Silver theme that is preinstalled on the Viewty. Only one non-standard theme can be installed at any one time.
You can also use a piece of software called Theme Manager to switch between themes and use custom icons and clock widgets.
You can find detailed step-by-step instructions on using EFS Builder and installing Theme Manager online at www.mygreatphone.com
As for the LG KU990 Viewty themes themselves you can find - among others - a Simpsons theme, a Matrix theme, a World of Warcraft theme, an iPhone theme and a Vista theme on the Viewty Themes Download Page http://www.mygreatphone.com/forum/local_links.php?catid=41
Remember: Know Your Mobile accepts no responsibility for any damage that hacking into your Viewty to upload a new theme will cause. Installing a new, unofficial theme using these methods may violate your Viewty's warranty.
Jan 08, 2010 | LG KU990 Viewty
I cant install my downloaded themes to my nokia E71
You could be facing problem in Installing themes which you have downloaded due to certificate issue, you can try following steps to see if it helps you:
1) Go to menu-> installations ->app manager -> options -> settings -> and change the software installations to all.
2) Check if your downloaded Theme files are of ".sis" extension and they should be S60 3rd Edition theme files.
Hope this helps you installing themes on your E71, You can download more E71 theme files from this site, it has a good collection.
Dec 21, 2009 | Nokia E71 Smartphone
How to install the theme in psp
go to a website that caters psp themes, you can google it if you want, then download the themes, save it on your mem stick, make sure that you copied it on the correct folder, you will see a theme folder. disconnect you psp, then go to settings on your psp then theme settings, there you will see your installed theme.
May 23, 2009 | Sony PlayStation Portable (PSP) Slim...
How to install theme in sony F305 mobile
i am not able to install theme in sony ericsson f305 how to install it
Apr 07, 2009 | Computers & Internet
HOW TO INSTALL THEME IN MY HTC P3400I
Jayshree, just do 1 thing. after installing the themes files be sure to keep the respective files in your My Device/Windows folder, were the existing themes files kept.
Now tap on start\setting\today u will get the theme list.
njoy!
Dec 15, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Installing a theme in nokia e61?
To install themes, and other applications, onto the Nokia E61 you will need
to download and install Nokia PC Suite on your computer. The program is
free and available on the Nokia Web site.
Once the program is installed the cellphone must be connected to the
computer through a cable, Bluetooth, or infrared connection. The PC
Suite program will guide you through the process. A cable connection
is the fastest.
PC Suite has an application installation manager. Use it to install
any themes or Symbian 60 programs you have downloaded. Once
the theme is loaded on the cellphone, use Menu > Tools > Themes
to find the theme name. Click on it and the phone will ask whether
you want to preview the theme or actually install it.
Sep 21, 2008 | Nokia E61 Smartphone
Theme installation
hello
you just have to transfer the theme file you have to your P1i and then it install by it self and you can find it in the theme menu
Aug 26, 2008 | Sony Ericsson P1i
Uploading a theme
If you want to upload a theme which has been downloaded from the Internet, you must have the installer or the folder which contains the necessary files.After you have these things, you can easily upload the theme to any file-sahring website or whichever site you want to upload your file to.
If you have a problem regarding uploading to a specific website, please mention it in your question.
Tell me if this helps.
Nov 26, 2007 | Microsoft Windows Vista Ultimate Edition
Nokia N91 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
