GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Problem for GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Ge tfx25jr
By tammiebsrn on Aug 19, 2008
ice billed up on bottom of freezer. water leaking from front of freezer.door is closed. where is the drain? how can I fix it?
Same Problem
Feb 22, 2009
-   Water leaking out of freezer, pooling in the bottom and all over the floor. -   Guest
Best Solution
posted on Aug 31, 2008
Helpful)
MNTECH
Rank: Guru  GE Expert
Rating: 94%, 899 votes
Defrost drain is located behind the freezer wall at the bottom of the freezer. Remove back cover and flush out drain using a turkey baster and hot (not boiling) water.
Comments:
Sep 07, 2008
- If you have the model you listed, that is the fix. It is a "fixya" not a "thanks for trying". If you can't fix it with the help I listed, you are not mechanically inclined enough to be asking for help on this site. The only way anyone can do any better is to come out and do it for you. Don't waste our time and give us a bad rating, just call for service and crack open your wallet.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #2
posted on Jul 09, 2009
Very Helpful)
midnitefyrfl
Rank: Apprentice
Rating: 100%, 1 votes
We just had to fix the same problem on the same model. It was so badly frozen that the hot water would just reach the ice, get cold and never make it through. We unplugged the fridge, removed the back panel and used a hair dryer on the drain tube. Worked much faster with less extra water all over. With a flash light you can see when the water finally clears. Double check by putting a small amount of water over the drain hole (inside the freezer) to make sure it goes down immediately.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE GSS25JFPCC / GSS25JFPWW
Questions and Unsolved Problems for GE GSS25JFPCC / GSS25JFPWW
Do you recommend GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator?
Answer
Answer
I have a GE Refrigerator Model GSS25JFPHWW, SN AH209748 that will not dispense water or make ice. ... (More)
Answer
Have GE 25.2 cft refrig. TFX25JR. In door dispenser willnot dispense ice, just water. Have checked... (More)
Answer
ge refrigerator model gss25jfpa ww is not dispensing cubed ice. water and crushed ice are... (More)
Answer
In addition to this, we have water pooling and freezing in the bottom of the freezer side, and of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE GSS25JFPCC / GSS25JFPWW...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
