Question about HP Office Equipment & Supplies
C5180 hp printer shows paper jam but find no paper to remove
  • karynolley Sep 26, 2008
    printer gives carriage jam message - cannot see any problem - without taking printer apart what can we do?
  • HP Master
  • 5,568 Answers
If labels were ever printed with it, you may have some trash hidden inside.
Many printers don't handle them well.
Posted on Aug 19, 2008
HP c5180 printer paper jam error
Please try these general troubleshooting steps for paper jam issue: Turn off your printer to allow the paper feed rollers to turn freely. Remove the rear access door and check the pressure rollers. Verify that they are clean and clean the rollers with a soft towel if needed. Check if there is any jammed paper in this section and remove the jammed paper from the rear access door opening. Make sure that there are no torn pieces of paper in the fuser area and duplexer slot. Check if the carriage moves freely. Use both your hands to remove the paper that is stuck in the roller in order to avoid tearing of the sheet. Discard any paper that is damaged, and then reload the paper into the paper tray. Unlock the print cartridge access door. Check if there is any packaging material or paper debris stuck on the small metal pressure rollers that ride on the main feed roller. Do not mix different types of paper. Load only one type of paper for a print job. Make sure that the paper meets the paper-handling specifications. Slide the paper-length adjuster against the end of the paper stack and do not overfill the input tray. Connect the power cord and turn on your printer. Try to print a sample and if the error persists, then try to reset the printer. Try to update the driver. If nothing works, then service the printer.
123 HP COM Setup Printer Quick Setup and Install Support
Mar 24, 2013 | HP Photosmart C5180 All-In-One InkJet...
Cannot clear CARRIAGE JAM on my c5180
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert technician to mend it.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Sep 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
Shows paper jam but no visible sign of jam
Open it up and follow the paper path. The paper sensor should be visible somewhere.
The paper sensor could be stuck, dirty or defective. Maybe covered in paper dust.
Apr 18, 2010 | HP Photosmart C5180 All-In-One InkJet...
Printer wont shutdown after paper jam
After removing paper jam, which may have been caused by using typing paper,which was a much lighter weight,computer was shut down,on startup printer had shutdown,no further problem.
Jun 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
Input tray jammed/locked
The input paper tray is removeable. So try the link below to try to get your all in one machine set up  again. http://h10032.www1.hp.com/ctg/Manual/c00737614.pdf
Jan 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper jam
push the button on the back
Jun 16, 2008 | HP Photosmart C5180 All-In-One InkJet...
35 people viewed this question
Ben Johnson
