No Spinning or reverse action on drum
I have a problem with the above machine. I have had this machine for approx 18 months but has now come to a halt mid-cycle through a programme, still with water in it, however the programme still runs through but there is no spinning or any other movement
Called an engineer!
Posted on Aug 20, 2008
Whirlpool cabrio started making a loud noise when spinning. I've replaced the suspension springs before. Is that all I need to order? It's been a while.
Sounds like the bearings are toast. These machines have a poor seal in the tub which allows water to penetrate the bearings, drying/rusting them out. Go on "youtube" and search your problem. I use a 2"X4" and a jack on the center shaft to lift the drum out. Bearing tool and shaft/bearing, seal kit is approx. $150. Should take you approx. 4 hrs. if you're handy.
Nov 28, 2016 | Whirlpool Washing Machines
Dryer not spinning on reverse
I would call the mfr because this may be pretty serious. I haved fixed them but I would have to see it. There are many variables.
Jan 28, 2013 | Dryers
Makes a noise like a jack hammer on spin,now for about 18 months is not getting worse
Probably the rear bearing is is no good. Check if there is any up and down movement in the inner basket or if by spinning the inner drum by hand if there is any noise.
Oct 16, 2010 | LG Washing Machines
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Hotpoint WD64 is not spinning or emptying
check the pump, make sure drain hose is not cloghed, ensure the belt is in the place, spin the drum a bit by pulling the belt. then give it a go.
Update me about your progress
Jul 24, 2009 | Hotpoint Aquarius WD640 Front Load...
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer drum not spinning
yes you will most likely need a belt.
Mar 11, 2009 | Kenmore Washing Machines
Not spinning
If the m/c is washing but not spinning, then u need to check the filter.
It is located behind the lower rear panel of m/c.
Remove panel and remove large black hose on the bottom of drum, there u will see the filter, remove and clean.
Refit and make sure the hose is on properly.Test.
If u have no drum action on wash or spin then u need to check the motor carbons, this can be done whilst u have the rear panel off.
If carbs o/k but still no motor action, then u prob have control board prob.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint Washing Machine (W540) stopped working, LEDs flash....?
You must get the filter out, as there is a very good chance that this is the prob, keep unscrewing it and try to move it about, then screw it back in again , and then out again, hopefully this will dislodge whatever it is that is holding the filtter in.
Plz rate thiese comments.
Thanks.
Dec 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Error 59 - Washer not spinning
find tech sheet at bottom of washer, behind kick panel on left and check error code there and if listed follow check for motor controller. if not draining either then check drain pump.
Mar 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
