It may be a thermal fuse.
On
many dryers, there's a thermal fuse (a heat-sensitive fuse that blows
if the dryer overheats) mounted to the exhaust duct inside the back
cover panel. The fuse is about an inch long. It's usually embedded in
black resin and mounted in a white plastic housing.
If the
fuse has blown, it has no continuity. When this happens, your dryer
either just stops heating, or it doesn't work at all. Be sure to
inspect the venting/heating system before replacing the fuse to put the
dryer back into operation. (You can't re-set this type of fuse.)
For good troubleshooting tips, go here:
http://www.repairclinic.com/Dryer-Troubleshooting
Http://www.partselect.com/dryer+dryer-wont-start+repair.htm
