Question about Dacor Preference RSD30 Gas Kitchen Range
Dacor duel fuel range
My 30" Dacor duel fuel range timer keeps beeping incessantly and displays F1. Turning off at the breaker does not work
  • Anonymous Mar 26, 2014
    It shows f1
  • Anonymous Mar 31, 2014
    selfcleaning 30 in
  • 725 Answers
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
6ya staff
SOURCE:
Beeping with F1 on display
See if F1 stops momentarily after pushing cancel. If F1 returns you have a failed control (electronic clock). The board can be repaired at our shop, www.fixyourboard.com or you can purchase a new one.
Best Regards,
Bruce
Jun 22, 2010 | Dacor Epicure ERD36 Dual Fuel (Electric...
My Dacor RSD305 duel fuel oven does not work.
you need service
when set the display starts off at min temp
if no heat rise is present it will shut off
check your house breakers first
Jun 06, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
Error Message F1
no your control is out and needs to be replaced. the alarm is in the control itself. most ge ovens cannot be used, will not go into the bake or broil mode
May 15, 2009 | GE Kitchen Ranges
Timer tone goes off with F1 display
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
The display panel for the oven control of our Dacor Model RSD308 Duel Fuel Range suddenly stopped displaying correctly. The display panel shows parts of numbers and letters so you cn't read temperatures or...
Once the display board stops showing the numbers and functions, you have to replace it. You could try and turn the breaker off to it. Sometimes this will reset the main board unit.
Feb 26, 2009 | Dacor Preference RSD30 Gas Kitchen Range
I have a RSD30R Dacor range. I was given the range and no manual. 1. Can I get a manual on line? 2. When the Range was pluged up in keeps giving a beeping sound and flashing F1 HELP, I am lost!
Short of replacing the board, try to reboot it:
turn the breaker OFF and keep it OFF for at least 15+ min
(30 sec reboot does not work with this animal)
good luck: i hope you've fixed it long ago...
Jan 21, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor ERDS30 clock and display OK, all bake buttons non responsiv
Most likely the interuption of power is what caused the problem. try shutting down the circuit breaker that controls the range for 30 minutes then turn it back on if this does not reset the electronics. You may need to replace the keypanel and /or electronic control as either or both may have been damaged by the power surge.
Dec 31, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
F1 shows on display and beeps constantly.
The F1 error code relates to a defective touch pad or clock (ERC). It seems that the reason for it in your case is some liquid entered the unit during its cleaning. Unplug the power cable and wait for few hours, In case it will not help, apart the ERC unit and and dry the touch pad and the clock. Good luck!
Apr 04, 2007 | Jenn-Air JES9800AAS Electric Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
958 people viewed this question
Top Dacor Kitchen Ranges Experts
Jaime Hernandez
Ekse
Axel Gringmuth
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
