Question about GPS
Nextar S3 I have a Nextar S3 GPS system and when I switch the power button to on all I get is a red light.
  • 5 more comments
  • idelpino Aug 19, 2008
    It doesnt have a power button...It has a switch that goes from "on" to "off" and a Menu Button. It is a touchscreen device
    I tried to reset itbut it didnt work
    I unplugged the power cord and left it off for 30 minutes and it still didnt work
    this next star support site doesnt help http://www.nextar.com/frontend/gps_navig...
    the manual doesnt help either
    It isnt the brightness of the LCD
    I tried plugging it in to the computer but it says the device has malfunctioned
  • 928 Answers
If you have already tried to upgrade the software of the Nextar or have attempted to do it yet are unable to because the computer no longer recognizes the device it is best if you contact Nextar and have the device replaced already as if the computer does not detect the device or indicates that it has malfunctioned there is no other way of reviving the unit in question.
Posted on Aug 21, 2008
    Brigadier General:
  • 6,966 Answers
In the hope that it is not a hardware fault, pls try:
  • charge the unit overnight;
  • verify that power is available at the charger/adapter plug;
  • turn on the device without the SD card;
  • connect the GPS unit through USB to a PC with the charger/adapter likewise plug in;
  • try the PC connection again without the SD card.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 20, 2008
    Sergeant:
    Champion:
  • 246 Answers
Problems is with your software
Try to reinstall the software to the device
  • 157 Answers
Hi
I think the guys have given you all the possible solutions
You may need to send it to a technician for review or send it for repair under warranty (if unit still has warranty)
Thanks
JigSaw
Fixya Team
P.S. Dont forget to rate this solution as fixya
Posted on Aug 19, 2008
    Master:
  • 638 Answers
I got it its the internally error in the switch.the switch is proper but the circuit which is supporting this switch is not working.you just have to replace the black colour capacitor which is located on the circuit and exceoting the commands of the switch.you can replace it through soldering iron.thanks.
  • 1,800 Answers
Plug it to the computer by using the usb 2.0 cable
and give it a upgrade firmware of its software.
some might say that its a power issue but the power is already
give the red light.
plaese rate this post
    Sergeant:
    Champion:
  • 258 Answers
Q: Why is there no picture?
A: The brightness may be turned down; adjust the brightness of the LCD.
    Genius:
  • 1,011 Answers
Dear,
check this link. hope it will helpful
http://paulstamatiou.com/2006/05/23/review-vantec-nexstar-3-hard-drive-enclosure
goodluck dear.
  • SALMAN NASEER Aug 19, 2008
    check your adaptor. is it correctily giving 5VDC or less. check adapter itself or try with another one..
    also check the physical health of li-ion built-in battery..
  • SALMAN NASEER Aug 20, 2008
    switch it off and then connect it to the pc and then switch on it..
    then see if computer says malfunctioning..
    i think in this condition it should say like this.
    u then install the driver . .if you dont have then download it from its site..
    hope it will work. ask, if further help required.
    Scholar:
  • 133 Answers
See the user manual if not work then go with a professinol technision
  • 6,487 Answers
Try this one first:
Press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully.
Hope that helps.......
  • 1 more comment
  • Mark Gil
    Mark Gil Aug 19, 2008
    There's a possibility that its a hardware problem, i may suggest you to take it to a repair center near you or call the manufacturer for repair or replacement if its still under warranty,,,,
  • Mark Gil
  • Mark Gil
    Mark Gil Aug 20, 2008
    the device seems to be bad already and it needs a replacement..
    Master:
  • 623 Answers
Try this next star support site
http://www.nextar.com/frontend/gps_navigation_systems.asp
  • ritchie dempacco
    ritchie dempacco Aug 21, 2008
    take it to a repair shop...
    Genius:
  • 2,035 Answers
Please unplug the power cord and wait for 30 min and then switched on ..if this does not then you need to give to service if within warranty give to the company or if its out warranty give it local GPS service center...
  • Anand Kumar
    Anand Kumar Aug 20, 2008
    the freezing may either be software or hardware failure. First, press
    the navigation software can load successfully. If the program still
    does not load, then the software may be corrupted. Also, if the
    internal memory fails to read or write and the software cannot load
    properly, it may be caused by hardware failure.You need to give for a service...
    Master:
  • 521 Answers
Try reset. it will help you.
  • tech expert12 Aug 19, 2008
    sorry but you have to take it to the repair center as it is malfunctioned.wish u luck.bye.
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Hold ON button for two seconds until Red HDD Power light turns green.
thanks
good luck
  • Asfiya Ahamed
    Asfiya Ahamed Aug 19, 2008
    Dear sir/madam,
    It is due to power problem. If the adapter doesn’t connect well, please connect the adapter
    correctly. If the built-in rechargeable battery is weak, please use the
    adapter to supply power or change the battery.
    However,
    if you suspect something is wrong with the unit, immediately turn the
    power off and disconnect the power connector from the unit. Never try
    to repair the unit yourself because it is dangerous to do so.
    thanks
    good luck
  • Asfiya Ahamed
    Sir,
    I think the battery may be dead. If the unit has not been used for a long period, the battery may run
    out of power completely. When the battery is weak or totally dead,
    there may not be enough power to turn the unit on immediately. Keep
    charging the unit a while longer, then try to turn it on again later.
    Or else
    It may be caused by hardware failure. In either case, please return the
    unit for exchange or repair to the retail location from which you
    purchased it, or contact us for further assistance.
    Technical Support
    1-888-849-0846
    thanks
    good luck
Nextar s3 gps need maps
The Nextar S3 does not need or come with a map update. That's what it's best feature. It works with the Satellite everytime you turn it on. I've had one since 2008. It is very dependable and reliable. However, I dropped mine last summer and it hasn't worked right since. Now, when I plug it in it says, "the battery is low."
I am not aware if it operate by battery. Now that they are gone out of business it is difficult, if not impossible to get it clear information on the S3. So, I just gave up, and recently purchased a Magellan GPS.
I miss it already. I loved the fact that I did not hve to download anything, unless it was music or something that I wanted to download. With the Megallan, and most computers today. You have to charge them, and download updates...tsk tsk...tsk...such a waste of time. I rather plug it into my lighter and go....
Mar 11, 2012 | Nextar S3 Car GPS Receiver
How do you charge the battery? Does it require a battery charger?
Yes, you need the power cord that will go from a 12 volt socket in the car to the GPS receiver.
Best Buy, Radio Shack or possibly Walmart should have one.
Here's one on Ebay for $7.99 and free shipping:
http://cgi.ebay.com/Car-Charger-Power-Adapter-Nextar-GPS-navigation-P-P3-S3-/260658702096?pt=LH_DefaultDomain_0&hash=item3cb0782710
Thanks for using fixya, and a favorable rating is appreciated if this helps you.
Feb 08, 2011 | Nextar S3 Car GPS Receiver
Why does my gps nextar show a red light and not turn on screen is black tryed pushing reset button but nothing happens
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 25, 2009 | Nextar P3 GPS Navigation System
Recent places not in memory in nextar gps s3
Unlock the SD card (just moving up a tab in the left side of your SD card). I hope it works.
Apr 08, 2009 | Nextar S3 Car GPS Receiver
Nextar S3 Application error in Navigate
You need the contents of the \ResidentFlash directory. You'll need to rename the MobileNavigator folder and the four gpspara files (0,1,2 and 3) then load the new folder and files from a device that is working. You will then copy your old \ResidentFlash\MobileNavigator\UserData folder from your backup to the new folder to regain any favorites you might have created. You should then be good to go. I use ActiveSync to talk to the S3. I'm not sure how else you might attach to it.
I have the ResidentFlash files but I have no place to post them. The files zip to about 5.3 MB.
Feb 27, 2009 | Nextar S3 Car GPS Receiver
Nextar S3
I NEED MAP UPDATES FOR MY NEXTAR X3-03
Oct 06, 2008 | Nextar X3-02 GPS Receiver
GPS Logo
128 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
