700t trotter cybex treadmill
I put some brushes and it still the same. when I try to start it .it says err 1.can you give me a hint of what to check. or should i send the complete printed circuit to be check . pleas let me know Maurice
    Brigadier General:
  • 6,966 Answers
Hi again,
Appreciate the direct "Ask Me".
To your concern:
  • Error 1 - No speed signal at startup. This indicates that the controller board did not sense that the motor is turning. Procedures call for checking of the belt, the SCR (triac) controller (with an analog continuity tester), the presence of 130VDC spike/startup supply (with a voltmeter) and the brushes. Since you have replaced the brushes, the others then.
Of course the above requires familiarity with electronic components and circuitry, the use of an analog multimeter and possibly soldering. Should you be uncomfortable, then perhaps as you posted, "send the complete printed circuit to be check".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 20, 2008
My trotter 510 treadmill doesn't turn on and just gives off this high pitch sound when turned on
oh, the trotter treadmill that is a workhorse of a treadmill. Question doubled edge. does it start?? or it does not Start. the sound if it does turn on may be coming from the motor which may need new brushes. Trotter is now Cybex fitness. they will have a part to make the repair
Oct 12, 2017 | Exercise & Fitness
Trotter by cybex model 900t code 8 error
Error 8, is a power fault error. This means the drive motor voltage dropped below 190 VDC for 5 seconds. This could be caused by worn motor brushes or the lower control board.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jan 04, 2014 | Exercise & Fitness
Cybex 600c trotter bike will not stay in manual mode then display turns off
Does anyone have a Cybex 600C Fitness cycle owner's manual and parts catalog?
Dec 03, 2013 | Cybex Exercise & Fitness
Key pad enter + numbers not working trotter 685
adjust the reed switch, test for open or faulty, clean it, and tight the connector fery weel , see the diagram attached
2) replace the batteries old by new ones, and clean the contacts batteries.
3) tight the ribbon cables for keypads, clean it too.
God bless you
Feb 22, 2013 | Treadmill Doctor Cybex Trotter685 900t By...
Cybex 445t err 1
Error 1 means belt didn't start (or no speed sense).
Speed sensor and motor brushes are usually the culprit. Most of the time this its just the speed senor is out of place. Remove the hood and next to the pulley on the front roller you'll see a little black pill with wire attached. Adjust the tip of that to where its sitting within about an 1/8 inch from the magnet on the pulley. Speed sensor can go bad and you can tell by using a voltage meter on the audible continuity setting. New speed sensor: Cybex CX 445T Speed Sensor Part # AX 21500
If that doesn't work check your motor brushes, continuity on communication cables and calibrate it. If that doesn't work you may have a much larger problem such as a bad motor. How to test your motor
Feb 07, 2013 | Cybex CX 445T Treadmill Deck
I bought a used Cybex Trotter 700 T treadmill that works fine except the increase speed (+) does not work. I tried to fix it and now all of the buttons don't work. Any sugestions?
Dear Sir:
This is probably a 1(faulty speed sensor or the 2( speed sensor is not plugged in properly. Its also possibly a 3(faulty motor control board or lower board+ 4( Main motor faulty. Adjust the speed sensor see the diagram.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for HELP
sincerley. God bless you.
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
164 people viewed this question
jasbo
jasbo
