Question about Sony KP-51HW40 51" Rear Projection Television
KP-61HS10 with 6 blinks
I have replaced a shorted bad G-Board with a new one from Sony parts and now TV gives 6 blinks. Any Ideas to check for?
  • 1 more comment
  • cherstjohn Sep 06, 2008
    Our TV was working perfectly one day and the next day we got the six blinking lights tried to turn it on.... no picture and no sound. Sony authorized repair person said high voltage coil and aud. block assembly needs to be replaced. At a cost of $580!
    We purchased the TV in 2002 and are wondering if this is the actual problem, a reasonable cost, and is the TV worth repairing. Given many bad reviews, is something else likely to go wrong?
  • Anonymous Sep 14, 2008
    Hello, i have a KP FS 57 , I had the blue screen and adjusted the screen voltages as described in various articles and it worked perfectly. Now after an hour or 4 hours or somtimes 10 minutes TV shuts off and I get 6 blinks. To get it on again means unplugging it for several hours. The only obvious signs of problems is a occasionaly fizzing HV block, I live in a fairly remote part of Fiji so its fix it my way or dig a hole for it, any ideas? Its seems to be a similiar animal to others with KP in the product line, it has cathode ray tubes.
  • Anonymous May 11, 2010
    Thanks for that, I am pretty handy with electronics the set works intermittently so It can't be a shorted transistor, the HV block has a slight case of internal arcing (again intermittently). There is no other visible signs of any kind bulging capacitors etc. So I am a bit lost and have no hope of getting anyone to look at it as i inherited it on a remote Island In Fiji in the South Pacific so any ideas would be helpful or I will have to dig a very big hole for it and that seems a awful waste, I have a manual for another similiar unit but not similiar enough, firstly I cant get into the diagnostic screen as I have a different remote. Sound is also intermittent but stays on once it starts (unless of course the six blinks kicks in again)
  • 125 Answers
Most problably the flyback and the horizontal transistor is shorted out you will need a tech to make some tests and determine if they need to be replaced
Posted on Sep 15, 2008
  • 3 Answers
Set screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Hope This Helps
Posted on Sep 06, 2008
SOURCE:
The standby light is blinking 10 times
TEN blinks - Check for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, "D" board.
High voltage in TV got problem and that's why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Parts are available but problem of High Voltage Protection (10 times blink) requires high expertise and experience of TV repair.
You must know how to test transistors, resistors using the multimeter if you are going to DIY.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to seek for an assistance of a qualified TV Technician to isolate the above faulty parts.
Parts are available in http://www.partstore.com/CustomContent/PSTOR_ECO/CustomError.htm#PartsearchSKUList
Hope I helped you.
Thanks for using Fixya.
Aug 09, 2011 | Sony KP-51WS520 51" Rear Projection...
Standby light blinking 10 times pause and blinks again will not power on
This blinking is an error code. If you contact Sony, they will provide help. Search Google for error code info.
Jan 11, 2011 | Sony KP-51WS520 51" Rear Projection...
TV won't turn on, standby light just blinks 9times off and on
There is some problme in G Board (power supply board) in your Sony KP-46WT520 tv that is why standby light blinks 9 times.
If you are handy with electronics stuff repair and can test/ replace parts in circuit board then let me know to provide you more technical info to fix tv problem.
Feb 03, 2010 | Sony KP-46WT520 46" Rear Projection...
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
My sony Wega KP-57WS520 TV blinks 9 times and the picture and sound won't come on.
the blinking is an error code telling you that tv needs a new power supply.. have your tv serviced...
Nov 17, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony 65 inch
Hi
Thanks for using FixYa. Ten blinks on Sony HDTV means-- Check Transistors Q8014 and Q8013 on D- Board for shorts, leakage, or bad solder connections. If the transistors are bad, then also check R8051 and IC8005, these are also on the "D" board.
Please do rate the solution and revert for further assistance.
Thanks Rylee
Sep 18, 2009 | Sony KP-57WS520 57" Rear Projection...
Led 10 blinks then turns off
According to sony,
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Thanks.
Jun 16, 2009 | Sony KP-FX532M91 TV
TV blinks and won't turn on
Check Q8014 and Q8013 for short,leaky componets and poor solder connections onD board and If the transistors arre bad ck R8015 and IC8005 on same board.
Dec 17, 2008 | Sony KP-57WV600 57" Rear Projection...
The tv goes on stand by mode by itself. My 57' sony does not turn on but remains in stand by mode. Blinks 9x then stops, then starts all over again. What needs to be done?
9 blink in your Sony KP-57WS500 shows error / problem in Audio section.
1= +19 volts &-19 volts are shorted by any reason on A and B board.
2= IC708 is faulty on A board
3= PS701 & PS702 (fuse) are open on A board.
Above are possible reasons of 9 blinks.
If you have electronics knowledge and have tv repair skills then check as per above info. otherwise I recommend get help of TV tech person or contact nearest Sony service center.
Thank you.
Oct 05, 2008 | Sony KP-57WS500 57" Rear Projection...
Won't turn on
Flashing or blinkings diagnostic code meaning;
Bad solder or loose, crack ,cold solder connections joint,you must reworks or resolder joint of the "D" board so it will works normal again.
Hopes it may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
