Question about Canon Office Equipment & Supplies
My Canon S820 photos do not resemble the color on my monitor. I use Photoshop 8.0. Do you have any answer to color manage what I see on the monitor vs. what is printer? Thank you
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Check my other posting on this.
Posted on Aug 19, 2008
My Canon Pro9000 MarkII prints photos with a red tint
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
Dec 29, 2012 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon iP4500 colour management
Try this setting. This might be different but try to point some similar preferences and steps then you can give it a try.
Open Control Panel (I'm assuming that the OS is Windows XP) click on Printers and Faxes.
Right click the Canon iP4500
Click Properties in the drop down menu.
Click on the tab Color Management
There should be a list of color profiles if the drivers were installed properly.
They are-
(Generic)
(Matte Photo Paper)
(Photo Paper Pro)
(Photo Paper Pro Matte)
(Photo Paper Plus Glossy)
The last profile is the one you want. Just above you will see the choice of "Automatic" or "Manual". Click on Manual and this force the printer to use the highlighted profile for all printing jobs.
Now click on DEFAULT.
Go back to the main Properties page and click on the General tab.
Near the bottom you will see "Printing Preferences"
click on that.
You should now be in a Canon ip4500 Printing preferences window.
Look for Print Quality and click "Manual"
Click on "Set"
Click on "Diffusion" and just above that there is a slider that should be all the way to the right.
Click "OK" to save the settings.
Now just below you will see "Color Settings"
Click "Custom" and then "Set"
Everyone sees colors a little different but the following settings print a photo that folks I show them too really like the balance of.
Cyan 4
Magenta -12
Yellow 0
Black 0
Intensity Slider in the middle
Enable ICM not checked (disabled)
Print Type set to Photo (you might want to try the other settings here to see how the prints look to your eyes)
Brightness Normal
Click OK to save settings and return to the Main Menu.
If you now go under the Profiles tab you should see you new profile there.
You can give it a special name like "Canon Excellent Profile Settings" clip_image001.gifor some other easy to remember name. This is the profile you want to use when you print a photo.
That is it...simple eh?
Now the other important part is in PhotoShop/PS Elements. Open the program and then open any old photo.
Under File, scroll down to Print Preview and click
If not open, click on "Show More Options"
Bring up "Color Management" in the box just below the "Show More Options"
For "Source Space" click ""Document"
This setting depend on the profile you shoot in, either Adobe RGB or sRGB. You choose the one you use.
Below that there is a setting for "Print Space"
You want to match that to your source, whether Adobe RGB or sRGB.
For the "Intent" letting I choose Perceptual.
Then click "Use Black Point Compensation" and that is it. Ready to print
Aug 08, 2008 | Canon Pixma iP4500 InkJet Printer
MY CANNON PRINTER IP3600 IS PRINTING RED IMAGES IN PINK
go to Edit > Color Settings, how is Photoshop Elements currently set? The first thing I would do is try setting it to "No color management" and see if you get better results. If this works for you, you're in luck, because color management gets tricky.In settings "No color management" does not produce acceptable results, you will have to start reading up on color management and color calibrating your devices, particularly your printer. You might want to also read Photoshop Elements Help topic "To print using color management."Most graphics software has setting for color management, but personally, I have always gotten the best results by simply turning color management off. Color management is primarily intended for people in a pre-press environment. Not everyone needs it. If you're not doing professional printing, first try working without color management before you assume you need it.
Apr 26, 2012 | Canon Pixma iP3600 InkJet Photo Printer
Linking photoshop and canon MP700 for best quality photos
If your pictures are shot at the highest setting on your camera, you should not have to do anything in Photoshop.
When you go to print make sure the print setting on the printer are set to the highest level.
Nov 09, 2009 | Adobe Computers & Internet
Using the IP5000 and Canon Glossy Photo Paper am
Every time I have had problem have had to replace ink.
Sep 05, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
I have a Canon S820 printer. The colors don't match Photoshop ver. 8.0. that I see on the monitor. Would you have a setting solution for accurate color management? Thank you
well..this is a bit tricky..each monitor has a temperature setting, among other things. So, to tweak this sort of item takes quite a bit of understanding. I recommend that you bone up on the canon first, then backtrack through your monitor settings, then to Photoshop.
Aug 19, 2008 | Canon Office Equipment & Supplies
Photoshop and the R1800
I had the same problem and read everything I could find about it. Finally after tinkering around, I discovered that printing everything using "Photo Enhance" setting produced the best pictures. Also, I use a calibrated monitor and print through Photoshop Elements 5. Lots of Luck! Cyndy
Jan 28, 2008 | Epson Stylus Photo R1800 InkJet Printer
Monitor displaying yellow tint
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
http://www.mydigitallife.info/2007/07/11/windows-vista-photo-gallery-yellow-tint-background-problem/comment-page-2/
http://www.walkernews.net/2008/07/15/how-to-fix-windows-photo-gallery-yellow-tint-and-photoshop-monitor-profile-problem/
Nov 27, 2007 | KDS Radius RAD-7 17" Flat Panel LCD...
41 people viewed this question
old marine
old marine
