Question about Canon Office Equipment & Supplies
I have a Canon S820 printer. The colors don't match Photoshop ver. 8.0. that I see on the monitor. Would you have a setting solution for accurate color management? Thank you
  • TxArtist Aug 19, 2008
    I just spoke with tech support at Canon. They suggest using Canon photo paper. The technician did not know anything about Photoshop 8.0. He tells me that Photoshop is the issue. Do you have any suggestions for setting up color management in Photoshop 8.0. Thank you so much.
    Where do I work with monitor settings? I am using Windows Vista. Thank you.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..this is a bit tricky..each monitor has a temperature setting, among other things. So, to tweak this sort of item takes quite a bit of understanding. I recommend that you bone up on the canon first, then backtrack through your monitor settings, then to Photoshop.
Posted on Aug 19, 2008
  • Patrique Davenporte Aug 19, 2008
    Thanks for Trying? hmmphg..you'll learn at the rate of your interests..
How do I print artwork getting all the colors to render accurately, so that it looks like the original painting.
Unfortunately you screen (computer or other ) isn't calibrated.
there is software mostly pro use this, but take a picture of a flat grey placard.
using your photo program to check the gamma settings and modify them until the grey on screen matches placard ( hold placard next to monitor). Then print out grey image.
important write down the gamma settings and when you put something to print check to see if these are close.
Sep 26, 2016 | HP Designjet Z6100 InkJet Printer
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
THE COLOR PRINTOUT IS DIFFERENT FROM THE ORIGINAL PICTURE; HOW DO I ADJUST THE COLORS ON THE PRINTER TO MATCH THE ORIGINAL COLOR?
What you described can mean one of two things.
First, that your monitor is not correctly set up for the colors, this is unlikely unless you have altered your display settings.
Second, You are running low on a certain color ink.
Mar 03, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I need canon irc 3100 scaner driver i connected printer but i cant scan
u can open canon india website and select your model no. and download the network scanning driver after download u can install your system and use photoshop for scanning, choose online scanning option in your zerox machine and scan through photoshop (click File-Import to canon network gear ver. 2.7. u can use feeder also while scanning
Dec 02, 2010 | Canon iRC3100 Printer
Scanning is not producing accurate colors for all colors. For example, Halloween shade of orange scans as pure yellow and brown comes out quite pink. Tried shutting the machine down and restarting much...
You'll need to calibrate your printer in order for the prints to come out with the correct color. In addition to this, if you're printing from .pdfs, you can set Acrobat to "print as image", this also helps in correcting the colors as they appear on your monitor, although this is NOT as accurate in correcting color as the "calibration" part.
Hope this helps. :)
Oct 06, 2010 | Canon PIXMA MP520 InkJet Printer
Picture color is pinkish and out of focus
there might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
Apr 05, 2010 | Canon PowerShot A95 Digital Camera
Linking photoshop and canon MP700 for best quality photos
If your pictures are shot at the highest setting on your camera, you should not have to do anything in Photoshop.
When you go to print make sure the print setting on the printer are set to the highest level.
Nov 09, 2009 | Adobe Computers & Internet
The printer does not prints exactly the colors that I see in my tft monitor.it seems that the printer adds a bownish filter in my images and prints them more dark-brownish. I print using ACDSee. I also...
Check your inks, especially the yellow, a bad printhead will allow the colors to cross contaminate. Usually yellow looks a brown color in the cartridge. You need to install a new printhead and toss any contaminated inks.
Jun 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Jan 03, 2008 | Epson Stylus Photo R2400 InkJet Printer
55 people viewed this question
old marine
old marine
