Question about Goodman Heating & Cooling
I have a Goodman AR48-1 air handler. About two days ago I smelled a burning smell and know the fan motor never shuts off, even when the condensor unit has shut off. Could it be the time delay relay. Any advice would help. Thanks Cliff
5 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Posted on Feb 19, 2008
  • 49 Answers
SOURCE: blower fan keeps shutting on/off,
Try putting your fan in the on not auto position and see if your outdoor condensing unit cycles on and off. If it does you might have a defective time delay relay to blower. If not your contactor might be stuck or your thermostat could be defective.
Posted on Jun 01, 2008
SOURCE: Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Posted on Jul 29, 2008
  • 124 Answers
SOURCE: bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Posted on Nov 01, 2008
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
My air conditioner on my 1999 kia sportage smell like smoking and like burning went turn on
do you turn on fan when using a/c ! if so heres a few causes-- burning smell in car, blower motor is going bad, or resistor is burning up.the resistor controls the fan speeds. good-day !
The burning smell could be due to gas leakage in the engine compartment. The gas smell is being sucked into the fresh air intake of the air conditioner. It can be avoided by checking either fuel pressure regulator or fuel injector.
Sep 24, 2011 | Kia Sportage Cars & Trucks
Hi contractor replace air handler motor now 4 months later pop
The mildew smell could have been created by the clog, but it also could have been created by low airflow and/or refrigerants leaks that can cause your evaporator coil to ice up and melt inside your air handler.
The "Popping" sound sounds like it is either your ductwork or the casing or access panel of your air handler.
If you still have the original ductwork, it should be thoroughly inspected for air leaks and/or degradation insulation (insulated will degradate in time). Re-seal and Re-insulate if necessary.
Without being onsite, with toolbox in hand, I hope you find this information to be very helpful to you, moving forward. :-)
May 03, 2010 | Intertherm P3RA-048K Air Conditioner
Freezer is all deforsted. Fridge is 5 years old. We smelled a burning smell 2 nights ago and now everything is defrosted. We couldnt tell where the smell was coming from in our house. Motor is running....
If the evaporator (freezer) fan and the condensor (bottom rear) fan are both running but you have no cooling at all, the odor you smelled was probably the compressor start relay/overload device. It would be in your best interest to have a professional service technician look at it. Proper repair could mean the difference between a $60 part, or a $300 compressor. Prices are for the part only.
Dec 23, 2009 | Refrigerators
Burning smell and icing
Sounds like your blower motor in your furnace or air handler has burned up. shut the unit down and replace the motor. make sure the ice is melted and the unit is dry before you turn it back on.
Jul 17, 2009 | Sharp CV-P09FX Air Conditioner
The model number as listed on the receipt is CKQ24. The Blower moter in the air-handler is not running. When the fan-only switch is turned on, the blower motor will attempt to spin by pulsing for about 2...
Personally I would get an exact replacement capacitor same voltage rating and microfarud rating. The capacitor will read something like 370v 5uf. I would be surprised if that's not the whole problem. If not it needs an exact evaporative fan replacement, and the new Capacitor. Happy cooling!
Jul 17, 2009 | Goodman CKL24AR24 Air Conditioner
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Fan whining and blades not going
Sounds like your compressor outside is frozen up or (locked up) the smell is outside correct? it could also be your fan also in your condensor unit outside the easiest way is to listen for fluid movement (if your freon is moving then your compressor is working and you need to lean toward a fan motor. check to see if you can move the fan blades in the compressor (outside ) if the problem is in the house then approach in the same way with the power to the unit turned off only If you cannot turn it most likely fan motor replacement is in order, and pressure sensors are not letting your condensor run. theres a few things to try hope i have helped .Honestly it probably would not hurt to let a service man look at it anyway, but this way at least you're a little wiser chris
Jun 12, 2009 | Goodman CLT36AER36 Air Conditioner
Brunt smell and sweating
Seems like your blower motor is burning up. Its the motor that blows cool air across the refrigeration coil. If it is a whole house ac unit, probably your main blower motor for the furnace. If you are getting sweat, that means the compressor is compressing the refrigerant, and you should not smell anything from the outdoor unit, only from the furnace. Hope this helps.
Jun 04, 2009 | Goodman CKL24AR24 Air Conditioner
Feb 17, 2008 | Goodman CKL49AR49 Air Conditioner
Heating & Cooling Logo
114 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
