Question about Panasonic Office Equipment & Supplies
Hi I have a Panasonic wireless projector, I can connect wirelessly to it through windows (it locates it at as a wireless device adn says connected). How do I stream my presetnations to it? I did try to use wireless manager 3 but it kept asking for a projector name which I don't seem to be able to find in any of the menu - it's a PT-735 NTE, and I would prefer to use wirelmanager if I could get it working? Cheers Noel
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
If you double click on the bottom right of the monitor that tells you there is a wireless, what does it show up as?? it has to show you the model and make that is what you need to use.
Posted on Aug 19, 2008
Will a standard b,g,n wireless usb adapter work on an NEC projector?
No. The projector isn't a computer. It can't download drivers and software to make 3rd party devices work.
Use a wireless bridge and connect to the projector's Ethernet port if it has one suitable for network display. Otherwise stick with a cable connection from a laptop
Sep 02, 2014 | Office Equipment & Supplies
Wireless capablity turned off in hp probook 4520s
You can use the wireless button or HP Connection Manager (select models only) to turn on and turn
off wireless devices.
NOTE: A computer may have a wireless button, a wireless switch, or a wireless key on the
keyboard. The term wireless button is used throughout this guide to refer to all types of wireless
controls. Refer to the Getting Started guide for information on identifying the location of the wireless
button on your computer.
To turn off wireless devices using HP Connection Manager:
? Right-click the HP Connection Manager icon in the notification area, at the far right of the
taskbar, and then click the power button next to the desired device.
- or -
Select Start > All Programs > HP > HP Connection Manager, and then click the power button
Jun 24, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
Trying to connect multiple computers but need wep code . where is it?
Hi Friend,
Please follow the steps in order to retrieve the WEP code from the router.
1. Click Start\ Run\ type cmd and hit enter.
2. In the black window type ipconfig and hit enter.
3. Note down the default gateway and close this window.
4.Open web browser and type the default gateway adn hit enter.
5. If you have not changed the default password of the router then type admin as the password and leave the username blank.
6. In the router setup page click Wireless and then click Wireless Security.
7. You may note down the passphrase and try to connect the wireless devices with this passphrase.
8. in case if there is something written in Key 1, then try this instead of passphrase.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 10, 2010 | Linksys WRT160N Wireless Router
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
I purchased an IMATION Projection Link. It did not come with a CD-ROM or User Guide. I am connecting it to an Optima 728 Video Projector with a VGA cord and an IBM Thinkpad operating Windows XP. When I...
I had the same problem with my Optoma ES566 and solved it by doing the following: 1. Connect the receiver to the projector using the vga cable. 2. Plug in the projector and the receiver. 3. Turn the projector and the receiver on. 4. With the computer booted, plug the USB dongle into an available port. The light on the dongle will flash green and then turn amber when the device is recognized. The projected image should change from the Imation logo to your desktop.
This sequence has always worked for me.
Apr 13, 2010 | Imation WIRELESS PROJECTION LINK (27242)
Network adapter not found when running wireless program
Sounds like the Apple Dealer is onto the right idea.Unfortunately wireless control for projectors is still in it's infantcy and subject to compatability issues. A complicated alternative is to "Try" a wirless bridge adaptor in between the laptop and the projector. using the lan port on the projector, you would set up a mini lan between the projector and the bridge, and you would get a wireless connection between the mac and the bridge.
Probably too complicated, the extra cable may just be the go for now until panasonic release the firmware upgrade for you.
Good Luck in the Courtroom!
Jan 17, 2010 | Panasonic PT-LB80NTU Projector
Want to download wireless internet to the system it is rum by windows 2003
What you need first is to install the wireless driver for your wireless card in your computer. If you don't have one you need to purchase a wireless card.
Then read the following info to decide what type of Internet access you require.
Wireless connections to the Internet can be achieved by several methods and it depends upon the method of delivery by the Internet Service Provider in your location.
The most common is by DSL and cable, the modems that are used with DSL and cable connection can have a built-in wireless router. Your computer will require a wireless card to connect to the modem/wireless router and the range is restricted to approx. 100 ft depending where the wireless router is located within the building.
The laptop's wireless card can be a built-in device or a plug-in device eg a PCMCIA card or a USB device. and these can also connect to a wifi hot spot in locations such as McDonalds. Star Bucks etc.
There is another method that can connect into the Internet that uses a USB wireless device that connects to a G3 network, bacically a type of mobile transmission and the device is locked into a specific Internet Service Provider. This method gives a wider mobile range (even across states) of connecting to the Internet but usually at a higher cost.
Basically you need to see what the Internet Service Providers offer in your location. Beware of the costs of the various plans they offer in broadband speed, their download limits and the penality for exceeding the limits etc.
When you decide which method you choose, you need to consider setting up your wireless network securely to prevent unauthorized access.
May 08, 2009 | Acer Aspire 3680 Laptop
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
MY WIRELESS ROUTER WILL NOT CONNECT TO THE INTERNET. The lights on the front are flashing. I have installed the modem adn router disk but it still wont work.....
If you have a modem connected to a wireless router that is connected to the computer, turn all the devices off and turn them back on in this order.
1. modem
2. wireless router
3. computer
let the device start up all the way before you start the next device. (I.E. let all the lights on the modem come on before starting the wireless router and let all the lights come on on the wireless router before turning on the computer).
Hope that helps.
Nov 10, 2008 | Belkin Computers & Internet
Driver for the Panasonic PT-LB60NTU
To my knowledge, the Panasonic PT-LB60NTU's wireless connection to a MAC is not supported, sorry.
Kind regards.
Feb 07, 2008 | Panasonic PT-LB60NTU Multimedia Projector
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
