Question about HP 1010 Plain Paper Inkjet Fax
Sent fax I have been getting alot of complaints from people I have sent faxes to, when they receive them they cannot be read. I have checked my phone line, ink..ect.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
The question is Why can't they read it????????
compressed, dark, light.......???????????
Posted on Aug 19, 2008
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
Hi havent received a fax for a day..just sent myself a fax from elsewhere but not received it...what settings should i check ? thanks .
Pick up the handset and check that you have "dial-tone" on your machine. If you dont, check and make sure you have the phone line plugged in to the "line" jack on the back of your fax machine.
If you still dont have dial tone, plug a phone into the wall outlet for your phone line and make sure it works.
Jan 06, 2011 | Samsung SF360 Plain Paper Inkjet Fax
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Sending and rec faxes
The protocol is failing after the check frame is received. Most likely noisy tel line, but could be attenuation problem. Either way, have the lines checked by telco.
Feb 26, 2008 | Office Equipment & Supplies
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Problem with the fax
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Oct 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix my fax
Oct 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fix the fax
HP 1010 Plain Paper Inkjet Fax Logo
60 people viewed this question
Ben Johnson
