Question about Symbol MC9060 Barcode Scanner
Freezing The scanners that I use freeze up when I put them on the charger overnight. I'm guessing that it has something to do which this particular charger but I don't know what it is. Can the charger itself cause this problem or is it most likely something else? We have 2 four port chargers and this only happens with the one I use.
    Problem Solver:
  • 8 Answers
Hello - if you are having any issues with your MC90XX let me know;
Ian
DC Solutions
ianv@dcsolutionsonline.com
Posted on Sep 30, 2008
Food freezing
Hi Susan,
I had the same problem with food freezing on the bottom of the compartment, especially the veggies. I had set the thermostat to 34 for cold beer but I guess the thermostat is off a bit. I put a thermometer on the bottom shelf to make sure that I had control of the temp and set my thermostat until it was 36 inside. The thermostat on the front reads 40. I guess that 38 might be the magic number for you.
Jun 18, 2014 | Whirlpool GI5FSAXVY Stainless Steel ...
Zeepad still freezing i want to keep it, i just followed instructs in box, charged it, held power down for three minutes, and now recharging for two hrs. any tips, i don't like returning things i purc
Upon first use, you have to charge the battery overnight. Then for every recharge, you may have to keep it connected to the charger for at least 4 to 6 hours depending on your tablet, otherwise, your battery will go kaputt in a short period of time.
Mar 12, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
My playstation 3 just started freezing up. It comes on and tries to find network but then just sits there. I can move the cursor over put as soon as i click on something it stops again and will not turn...
Hello
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down.
If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on.
Check if there's any loose cables. If there is, put them back in.
If the freezing continues after taking the above step, you can follow the link below as a guide on how to fix the problem.
http://www.squidoo.com/PS3-Repair-Guide
Good luck
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Fridge not cooling
unplug unit and let sit overnight to defrost,
Oct 29, 2009 | Refrigerators
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Cannot turn Palm TX on after listening to music. Button protection was set to "on". Now I cannot turn it on with any buttons. Tried charging with wall charger overnight. The case normally gets warm on...
Something similar happened to me. I finally gave up on my wall charger and tried connecting my PDA to my computer and pressed reset button several times. I left it connected overnight and It was working by the next morning. My guess is that my battery was completely drained and my wall charger quit working.
Jun 28, 2009 | Palm TX Handheld
Older Superior Brand Kegerator Freezing
Sounds like the fan can be running backwards. I'm not sure of you exact model, but it has to match the air flow of the original unit. Do you remember? Some manufacturers use reversable motors and are some what easy to reverse.
Good luck and hope this helps.
May 08, 2009 | Danby DKC645BLS Compact Beverage Cooler
Low battery display
My first guess would be to take a volt meter, and check the power pack to see if it's putting out the correct DC voltage(or any voltage). Those things are super cheap!
Then check the plug in on the scanner to make sure your getting a good connection(might have a broken connection to the circuit board). If those are 2 year old rechargeable batteries, they might be getting close to laying down and dying. Hope this helps,, Mechanic
Oct 22, 2007 | Radio Shack Pro-94 Scanner
Symbol MC9060 Barcode Scanner Logo
156 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
