Question about Cameras
Not a problem - looking for a wide angle flash diffuser W1-A (Minolta p/n8805-500) for a Minolta Flash 360PX. Where can I look?
    Sergeant:
    Champion:
  • 258 Answers
Wolf camera, B&H photo video, ebay, etc.
Ken
Posted on Aug 19, 2008
Wide angle defuser is broken Minolta 5600hs
It's not a problem if you're not using a wide-angle lens. And if you are, you can always diffuse the flash by putting a thin white handkerchief or even a sheet of tissue paper over the flash.
Jan 10, 2013 | Konica Minolta Minolta 5600HS D - Hot-shoe...
I have a sony a200, i want to fit an external flash for that.
The camera already has a hot shoe that will accommodate a Sony flash unit or a third-party flash unit designed for Sony cameras. You don't need anything else (other than the camera and the flash unit, of course).
Mar 01, 2012 | Sony Alpha DSLR-A200 Digital Camera
I purchased a Tokina SD 11-16 F2.8(IF)DX from Japan. When I returned home and tried it on my Nikon 50 it gave me great results when I use without flash. The problem is that when I use it with my integrated...
The angle od the flash is probably not large enought or wide angle enought to cover the area the lens takes in. try using a softbox or diffuser attachment and makes exposure adjustments accordingly
Feb 19, 2011 | Cameras
The wide angle diffuser panel of my 530ex speedlite broke and I just got the replacement but I don't know how to install it.How can install it?
Can you tell me how you finally replace your wide angle diffuser on your Speedlite please?? I got the same problem. I have order a new wide angle panel and I'm unable to insert it in my flash.
Nov 19, 2010 | Canon SPEEDLITE 580EX TTL Flash
Minolta Electroflash 360px will not fire.
Hate to be the bearer of bad news sounds like my camera! The capacitors are notorious in these cameras they dry out if you don't use the cameras regularly and they need to be replaced most camera shops are aware of this. The parts are available to them on micro-tools.com if they have a hard time sourcing them. Hope this helps
Dec 08, 2008 | Minolta X-700 35mm SLR Camera
Zoom range 14-17mm
make sure the diffusion dome and the built in wide angle adaptor are off. If the diffusion dome is on, it will only work as 14mm and 17mm without the diffuser but with the wide angle panel.
May 10, 2008 | Nikon Speedlight SB-800 TTL Flash
Reinserting the wide-flash adapter in a SB-800 speedlight
The tab normanally breaks and you have to replace it .
There is six parts to replace... two springs , tabs , diffuser and also spring .
If you want me to fix the unit contact the address below .
Berrie Smith Camera Repair
BBMW@BELLSOUTH.NET
Jul 20, 2007 | Nikon Speedlight SB-800 TTL Flash
Help, White spots on photos with W1
Could be dust reflecting the flash. Water droplets also do it. Here's an example from an indoor trials where they had little RC cars on a dirt track next to the trials. The RC cars kicked up dust. The flash just bounced off the particles. This is an 828 with a Metz flash with a pocket bounce/diffuser on top. With the smaller camera with the flash more on axis of the lens the effect will be more pronounced since closer dust particles will be illuminated.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Is the wide converter attachable?
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
