Question about HP Officejet 5610 All-In-One InkJet Printer
Lexmark printer stuck in copy mode
Help i can't print don't know what to do
    Genius:
  • 1,605 Answers
Unplug the printer and let it set for 10sec to 20 sec. plug it back in.
wha tis the porblem???
Posted on Oct 10, 2008
3 Suggested Answers
Patrillica
  • 141 Answers
SOURCE: Printer "stuck in copy mode"?
Need the model of your printer..????
Posted on Mar 26, 2008
yooperbud
  • 8637 Answers
SOURCE: Can't get Lexmark X5410 to print. Printer is on "Copy Mode"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
How to get in to service mode on a lexmark x782e mfp
Diagnostics mode: power off unit. hold the 3 and 6 buttons and power on, holding the buttons for 10 seconds
Configuration mode: same as above but hold the 2 and 6 buttons.
Aug 30, 2014 | Lexmark X782E Laser Multifunction Printer...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
I can't print an alignment page from my computer. How do I align my computer?
Alignng your Lexmark:
1. Load paper in the paper tray.
  1. On the control panel, press Mode repeatedly until Copy is selected.
  2. Press Options until MAINTENANCE appears.
  3. Press + until Align appears, and then press Select.
An alignment page prints. Once this page prints, your automatic alignment is complete.
This works on Lexmark Printers, if it doesn't let us know what model you have.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Lexmark All-in-One Printer with PictBridge
Will not switch to copy mode
Make sure the Fax Mode button is not stuck in the printer. If not, unplug the power supply of the printer. The power supply is the black box behind the printer where the power cord is attached. Then, hold down Start and Cancel buttons at the same time while plugging back the power supply in the printer. Hold down the two buttons firmly while the printer is powering on until Language Selection appears on the LCD screen. Then, release the two buttons. Choose your preferred language. Set your printer like how you set it the first time. If this doesn't help, I strongly suggest you contact Lexmark Technical Support for further assistance.
Jun 07, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Same problem with x5650, using a genuine lexmark cartridge
Okay, sometimes the contacts points on the side of the cartridge are contaminated. Take a clean (pink) pencil eraser and rub the contact points. Blow any residual off of the contacts and then reinstall the contacts. Some Lexmark printer require that you use the maintenance utilities to install the cartridge and align it. It concerns me that the printer sees the cartridge when you make a copy. I strongly suspect that the cartridge is defective. Otherwise why would it fail in one mode and not the other. Have you verified the driver properties to make sure that you are not set for color only printing? Software will override the setting on the printer. Don
Jun 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
Jan 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Will print but not copy or scan
sir,
click this link to solve your problem
thanks
good luck
Nov 26, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
X6150 Copy problems
Had exactly the same problem. Solved by turning copier on, then unplugging it for 30 seconds..plug back in...Problem solved.
Mar 21, 2008 | Lexmark X6150 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
97 people viewed this question
Ben Johnson
