Question about Samsung (SP1614C) 160 GB Hard Drive
Samsung 160 gb
Powers of after 30 seconds
    Master:
  • 505 Answers
Need little more details than that please
Posted on Aug 23, 2008
My phone Will not turn on
Have you tried to reset. Remove the battery, leave it out for at least 30 seconds. Replace the battery and turn on again. For certain problems this works, and the phone will now power up normally.
Jan 05, 2013 | Samsung Wave (2 GB) Smartphone
SAMSUNG GTS7070 WONT TURN ON
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 02, 2012 | Samsung S7070 Diva Cell Phone
Trying to pair b250 xt with samsung rugby2 lots manual
Make sure you device is in visible mode first. In power off condition of headset, press on button for 30 seconds. When blue lights starts blinking fast then search on device and add it.
Custom Car Grilles
Aug 01, 2012 | Parrot Blue B250xt Bluetooth Wireless...
My samsung infuse will not turn on
5.Wait 10 seconds.
Step
Thanks
Jul 23, 2012 | Samsung Cell Phones
Acer x3400 wont start up
Remove the Power Cord and then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in and press the power button. If it reboots you had a Static Charge Buildup and released it by holding the power button for 30 seconds.
When you press the power button do you hear the fan running, disk drives running, cd drive clicks once, anything on the lcd screen? If not I would think your Power Supply is bad and needs to be replaced.
It's either the Power Supply or Motherboard.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
THE SWITCH ON IS NOT WORKING CAN YOU HELP ME TO FIX IT
The Switch ON? Are you talking about the Power Button? If so it could be that your Power Cord is bad. Some models of the Power Cord has a light on it and some laptops light up somewhere when the power cord is plugged in and working.
You might have been working off your battery and if the power cord is bad it was not charging the battery and now nothing will work because the battery is completely drained.
If the power cord is good, you might have a Static Charge Buildup. Remove the power cord and the battery, then press and hold the power button for 30 seconds. After 30 seconds put the power cord back in (not the battery, leave it out) and press the power button. If it starts booting you had a Static Charge Buildup and can put the battery back in now.
If all fails, take an ink pen and stick it inside where the power cord goes. If it is not tight then the DC Power Jack is bad and need to be repaired. This will require a complete disassembly of your laptop.
Mar 23, 2012 | Samsung N150 Netbook
My transcend 500 gb is not getting detected by laptop,power of hard disk automatically turns off after 30 seconds
check all leads from motherboard to hard drive including electrical extensions and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
hope this helps you
Mar 08, 2012 | Transcend StoreJet 320 GB USB 20 Hard...
Tv will turn on, for about 30 seconds, then it will shut down
Hello
There are two main reaons for this fault. The first is with its power regulator board itself. If it has any loose soldering points developed, this type of intermittent fault can occur. The second is with its light engine. If you want to do this work by yourself, you must have thorough knoledge in electroncis, and must have all tools and ability to follow its schematic diagram. The most you need is patience. If you have these all, and want to do the repairwork by yoursef, inform me. I've the schematics of your tV, and all repair adjustments and proceedings. The power supply board and lamp ballast boards for Samsung (HL-T) series are shown here for your referecne. The lamp ballast board also may need to be checked.
Nov 16, 2011 | Samsung HL-T5676S Television
I have Asus Eee 1005AH. Only starts up if I remove than replace the battery. I have to do this every time I want to use the netbook. Please Help!!
Take out the battery, and unplug the AC adapter, so there is no power to the computer. Then, press and hold the power button for about 30 seconds. This discharges small capacitors inside of the computer, which are like mini batteries that keep things running smoothly when your power source isn't the highest quality, like from the wall. Hopefully this solved your issue!
Aug 19, 2011 | ASUS Eee PC 1005HAVU1LBK Netbook PC Atom...
Samsung (SP1614C) 160 GB Hard Drive Logo
113 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
