Question about Canon Office Equipment & Supplies
I use a Canon BJC-2100 printer.The unit that contains both BC-21e color and black cartridges is faulty. I mean that the unit, which has a metal plate that contacts with the printer, doesn't transmit anymore a signal to the printer. What can I do ?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well if it's under warranty you are in good shape..otherwise, it's quite a lot of more money..around 200 at least..
Posted on Aug 19, 2008
SOURCE:
Green light is flashing on printer - cartridge won't slide back and forth so 4300 printer will not print
If cartridge is in the middle and won't reset to the right, it is likely a bad printhead (BC-21e).
Jan 18, 2010 | Canon BJC 4300 InkJet Printer
I have a "BJC-4400" printer that has a cartridge holder for a BC20 cartridge. I'd like to replace it with a holder for both black and color cartridges. ~ Bob V
You will be able to replace it with a BC-21e cartrige adapter witch will hold colour and black cartriges in the same spot!
Here is an image of what it looks like:cbad7e0.jpg You will need to purchase the
BCi21BK Black ink tank 2af5c22.jpg and the BCi21C Colour ink tank
6ef4d60.jpg which are all available from http://www.stinkyinkshop.co.uk/acatalog/Canon_BJC4400.html
or your favourite ink provider source.
Jul 18, 2008 | Canon Office Equipment & Supplies
Will not print
Check on Canon.com, for the users manual, When you install cartridges you hold the resume button for the number of beeps to identify which cartridge is installed. You can install one black ink or one each black and color but you have to tell the printer which is installed.
Dec 28, 2009 | Canon BJC 85 InkJet Printer
My Canon Bjc-2110 has new cartridges but nothing prints. I cleaned the heads and still nothing. Any ideas?
You need a new printhead, BC-21, after they dry up the normal cleaning doesn't help. BC-21E is the printhead and ink combination.
Nov 20, 2009 | Office Equipment & Supplies
Canon BJC 4400 won't put ink on the paper
You need a new printhead, BC-21E, they wear out and plug with ink and the only repair is to replace the printhead.
Sep 16, 2009 | Canon BJC 4400 InkJet Printer
Error light and 6 beeps upon startup, therefore the printer won't print anything.
Is the BC-21e new, or refilled?
I know Cannon brand new cost so much more, but sometimes you have to bite the bullet.
I had a Cannon Multipass C2500.
Sometimes even a new cartridge isn't good enough. I used to exchange between that one and the all black cartridge, because the all black has twice the resolution. Even with very careful handling, not touching anything metal, they still went bad.
My best suggestion, short of another expensive cartridge is to remove the cartridge, take a soft pink pencil eraser and lightly erase all the contacts on the printer and the cartridge. Look for any of the spring loaded contacts in the printer that are stuck. Do not touch the contacts on the cartridge as they are unbelievably static sensitive. If you see ink on the contacts, use rubbing alcohol and a q-tip to remove it.
Most likely though, it will take yet another cartridge with head to fix it. (That's why I gave up on mine and got a different brand.)
Apr 13, 2009 | Computers & Internet
Colour/black cartridge is rejected
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Canon BJC 5500 InkJet Printer
Cartridge recommendations
You can purchase Canon cartridges directly from Canon here. The BC-10 is a cartridge that prints with black ink only. The BCI-10 is the replacement ink tank for this cartridge (a new cartridge comes complete with an ink tank). The BC-11e is a cartridge that prints both black and color, and has two ink tanks, the BCI-11 black and BCI-11 color. A new BC-11e cartridge comes complete with two new ink tanks.
Oct 03, 2008 | Canon BJC 80 InkJet Printer
Printer won't print
It always helps to replace with the correct brand as cheaper versions do fail, also if you had replaced it with a BC-20 from Canon, the supplier may replace it for you. It would be a good idea to trust the printer at this stage, try a Canon BC-20
Sep 07, 2008 | Canon BJC 4300 InkJet Printer
Canon printer bjc 85
you need a new printhead, either bc10 for black or bc-11 for color, you also need to check your owners manual to set the printer for the correct printhead type.
Dec 17, 2007 | Canon BJC-85 InkJet Printer
Open Questions:
Clive
Clive
old marine
old marine
Ekse
