Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
GSS20IEPHWW GE REFRIDGERATOR
THE ICE AND WATER DISPENSER ARE NOT WORKING LIKE THEY SHOULD. WHEN TRYING TO DIPENSE ICE THE LIGHT GOES VERY DIM. WHEN TRYING TO GET WATER IT WORKS SOME TIMES BUT NOT EVERY TIME. ALSO WHEN THE FRIDGE IS RUNNING WHEN TRYING TO USE THE DISPENSER THE MOTOR ON FRIDGE STOPS RUNNING, BUT WHEN LIGHT GOES OFF THE MOTOR STARTS BACK UP. PLEASE HELP.
  • 639 Answers
Friend,
ngfam1 At your service!
You have an electronic problem and need a service tec to diagnose it!
If you want you can unplug the fridge for 3 minutes and the restart it ! See if it reboots correctly!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New applinces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
I have a General Electric GSS20IEPHWW fridge.on occasion pushing the buttons for ice or water the dispenser will not operate. The dispenser light comes on very dim. The only thing that seems to help is...
the p c board is the problem. however it may not be bad. ck the connections on the board . . unplug frig when doing this . ) clean the connections you can get a spray cleaner at radio shack that will be safe to use on the board . if cleaning does not correct then look for bad printed cur . as the board may be cracked . . if so leplace board. Part # wr55x10443 cost about 80 to 90 .00 . so you might want to clean the connections before replaceing the board . its a easy job. hope this helped ****
Jan 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
GE refridgerator/freezer light dims when trying to use ice maker
check the ice bin to see if theres something binding the auger up. take it out and thaw it is so.
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water Dispenser works intermintently, Ice dispenser never works
Called GE Service Dept. My refrigerator was way out of the warrant period. They came out and replaced the main circuit board at NO CHARGE.
Jan 12, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Ice Maker Isn't working
water to the foutain is not the same water to the ice maker . ck the dual water valve ..
Mar 25, 2008 | GE PFSS6PKSS
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
226 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
