Question about RCA P52926 52" Rear Projection Television
2001 52" RCA Rear Projection Home Theater Model P52927
The television worked fine then while watching it it started switching channels on its own. It runs through every saved channel from lowest to highest. When it gets to the top of them it starts at the bottom and does it all again. Neither the remote or the buttons will work on the television.on the unit will work at all. We have unplugged it for up to 24 hours and when plugging it back in it will turn on on its own and start the whole process over. Any suggestions
  • jbrenmfc Aug 20, 2008
    My tv is doing the same thing. It also turns on by itself and starts going through the channels. I was able to watch an entire movie last night and it didn't do it at all for some reason. I was also able to swich to video 1 for a short time to play video games but it automatically switched to tv and changed channels. I unplugged for about eight hours and looked for a reset button. I also tried to go to menu but it keeps switching on its own. Any ideas are appreciated.
  • JChavis84 Sep 08, 2008
    Wow, I'm not the only one! I've had this television for years now, and the exact same thing is going on. Some days now it won't even turn on, finally today after about a week a start hitting the power button about 5 times, and it's back on! But again with the same damn channels counting down. Another thing it would do sometimes do is, the volume would start going up and up and I'd have no control over it. Would love to know what's going on too. Please someone help!!!
5 Suggested Answers
  • 6 Answers
SOURCE: RCA 60" projection tv Turns on and starts flipping channels by it self
replace the keyboard or remove the switches for channel up/down to see which one is bad. if neither does it, there are some components around the microprocessor that can cause this.
Posted on Jul 28, 2007
  • 927 Answers
SOURCE: RCA P52927 52 in. Projection TV
You have a convergence problem, try unplugging power for 5 minutes. Call factory authorized service center.
Posted on Jun 01, 2008
ladywinn
  • 5138 Answers
SOURCE: 52" rca projecion tv will not come on i broke it down and there is a faint beebing sound comming from the transformer area
Chances are you have 3 bad capacitors 2200uf 16v cp150/ cp111 is 330uf 35v / cp114 is 220uf 35v they are green with gold writing on them.
Posted on Oct 09, 2008
tlm931
  • 273 Answers
SOURCE: reset button on 52 in rca rear p52940 home theater
this set does not have a reset button if there is a system lock out unpluging it for 3 or 4 mins will reset when pluged back in
if that does not help try trouble shooting the set ck the ac fuse and so on
Posted on Oct 24, 2009
Picture problem with a rca home theater model p60752eb
I have a problem with the colors on my RCA Home Theater model #P60752EB. I believe it to be faulty tubes or something cause my green and my red color is messed up to the point it will not come in at all.what should i do to resolve this problem without replacing the tv
Feb 15, 2009 | RCA P52926 52" Rear Projection Television
RCA Home Theater (Model #P46924) No Picture, just sound
Sounds like a possible solder issue with the vertical output IC. Try resoldering the Vertical output IC connections
May 17, 2008 | RCA P46924 46" Rear Projection Television
RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
RCA model P52927
let me get some info how to get the screen off and I' get back to you... e-mail me networks@q.com
Mar 23, 2008 | RCA P52926 52" Rear Projection Television
RCA Home Theater Premiere
unplug the TV for 4 hrs. and let it reset to factory settings and then start from there scan for channel line up in the menu.
Jan 30, 2008 | RCA P52937 52" Rear Projection Television
Nov 18, 2007 | RCA P52926 52" Rear Projection Television
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
Rca home theater problem
The trouble is the front panel buttons,unplug the unit and remove the back cover,just below were you removed the top screws,you can look under and see the top of the tubes,there is a small board in front of the middle tube,unplug the right top cable off this board and you can use your remoten till you can get it serviced
Oct 01, 2007 | RCA P61927 61" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
125 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
