My Canon i80 will not feed paper for printing into the printer.
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Posted on Jul 17, 2012
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmm..did you check under the feed tray and inside for paper obstructions?
Posted on Aug 19, 2008
I installed the Canon i80 driver and the printer is recognised by my PC however when i try to print the i80 does all the actions but no ink is shown on the paper. I have checked the print heads and the...
I know it sounds daft.. i had this on a word document... although the text was showing in black it was printing in white. try changing the text colour to black... hope that helps
Jan 10, 2011 | Canon i80 InkJet Printer
Hi, my canon i80 printer wont feed paper through
Sep 16, 2010 | Canon i80 InkJet Printer
Will not print full page to EeePC laptop,But will print to full size laptop.Is there something I can download to make it work.
Mozilla has a program with i80 canon printers,
So just don't use it,us different engine to look up and print from.
thanks for trying
Nov 05, 2009 | Canon i80 InkJet Printer
Splotching and spotting ink
The roller cleaning will require you to remove cover to clean the full roller with alcohol to remove ink build up. Have you tried to just run/feed a blank piece of paper through to see if you have roller ink roll off?
This also sounds like a bad cartridge with clogged jets...
Jun 15, 2009 | Canon i80 InkJet Printer
Sounds/looks like it's printing but paper comes out clean - there's lots of ink and I've changed the ink levels
Hi, have you checked to make sure you removed the sticky tape cover from the end of the cart?
Sounds silly I know but I have done this before & it's easy to forget when your in a hurry :-)
Cheers
Sham
Jun 01, 2009 | Canon Bubble Jet i80 InkJet Printer
Black doesn't print well
printer doesn't give print out, all the maintenance has been tride but desn't give print out.
Apr 06, 2009 | Canon i80 InkJet Printer
Canon i80 printer
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Canon i80 InkJet Printer
MY PRINTER
i AM GETTING 5C00 ERROR
Aug 27, 2008 | Canon i80 InkJet Printer
I80 black cartidge not printing
get a q-tip and wet one end in water.  run wet q-tip along head a few times.  then take dry end and run along head again to dry it.  then run wet end again on the absorber side of head.  then dry with dry end.  replace parts, do a deep cleaning, and try a test print.
Apr 27, 2008 | Canon i80 InkJet Printer
I80 paper jam
CHECK IF THERS SOMETHING UNDER THE INK TANKS
Feb 27, 2008 | Canon i80 InkJet Printer
137 people viewed this question
jasbo
jasbo
