SOURCE: Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?z=234&service=EU&from=faq_selection&CFID=BIOS&FID=TRO0000000b07
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
SOURCE: Toshiba Satellite A65-S1762 makes one long beep then two short when turned on
Sounds like video problem.
My wife has one of these and it died.
One file came up corrupt and then after I restored it the system would just drop power without warning.
Then would hang in safemode at an ATI sys file for the video.
It's on the mainboard. These also have built in RAM problems too.
You can try to remove any additional RAM you may have added in the bottom slot and try to boot.
My best advice is get a $20 best buy/staples 2.5" USB HDD enclosure and throw the HDD in there and toss the leftovers on Ebay with an explanation.
You'll get $100-150 for it to help buy yourself a new one.
Sell the LCD as one deal, the keyboard another, AC adapter another and so on. You'll get more that way.
I'd go Fujitsu. Toshiba used to be good but they went to **** to compete with HP/Compaq and sell at Walmart.
Gateway is also decent. The key is newer laptops run too hot and end up toast in a year or two.
Buy something a little less frantic in the GhZ dept. and it will last longer.
Pushing a laptop for gaming or 3D graphics is hardly it's best use. Manufacturers are too busy adding flashy selling points instead of practical features like lighter weight and longer battery life.
SOURCE: toshiba satellite p305d-s8818 drivers seem to be
You can download the drivers from the link below
http://tinyurl.com/6s6sah
click on download,button to see driver donloads.
Thanks
proton
Do rate the solution ...
SOURCE: Toshiba Satellite p305d-s8828 will not BOOT.
try getting into BIOS and check if the boot seq is fine or if the HDD is not recognised...
press f2/f1/home/del key etc to get into BIOS after the machine starts....
the only option is to reload OS if they machine is booting into BIOS but not loading the boot/OS files
SOURCE: Laptop IBM ThinkPad. Black screen. Short beeps: 1+3+3+1
You can try the following steps:
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3.
Remove the battery and press the power button of the laptop for 15
seconds, after that, plug the power cord and turn on the laptop (if
4. Remove the power cord and
press the power button of the laptop for 15 seconds, disconnect the
Hard drive and turn on the laptop (If this didn't resolve the issue)
reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6.
Remove the memory chip, if you have 2 memory chips installed in the 2
memory slots (remove both of them) now test each one of the memory to
each slots turning on the laptop. (If this didn't resolve the issue)
Put the memory chip back in. (Clean the slots if there are large amounts of dust)
7. Reseat the CPU and try to make
sure that it's installed properly. Turn on the laptop and test if it's
gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10.
If all else fails, there's a big possibility that the problem may be
with the power supply or the motherboard of the laptop.
