Question about Frymaster Dean MJ45EMSD Deep Fryer
Oil drip oil is dripping from somewhere by the drain nozzel by burner areaand insulation catches on fire? Are their free pdf manuals for this and other models?
    Champion:
  • 254 Answers
Here you go
http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
You will need to use the 1st drop down to select service manual.
Use the 2nd drop down to select MJ45 series fryers.
Thanks
Posted on Aug 28, 2008
Antifreeze in breather box 97 1300 yamaha tour deluxe
Hi, Anonymous not good better call your dealer for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Tips Tricks
Yamaha XVZ 1300 Royal Star Tour Classic 1997
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
OEM parts for Yamaha
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
Jan 05, 2014 | 1997 Yamaha Royal Star XVZ 1300 A
Vw t25 gearbox oil change
You will need a very large allen wrench (like 19mm or so) for the drain and fill plugs.
This is an uncommon size so if you do not want to invest in one just have a shop do it.
If you decide to go ahead, get GL-4 hydraulic oil and a pump. Remove fill plug first (to ensure you can before draining transmission!) on side of transmission, about mid-line.
Then remove drain plug (center bottom toward engine). Have catch pan ready.
Once it has all dripped out, replace drain plug and fill with pump through side plug until it starts to drip back out (car level).
Let it finish dripping out, replace plug and good to go!
Jan 20, 2013 | 1986 Volkswagen Wagon Camper
Oil drip with oil smells like gasoline
Could be 2 problems. Some rear main seals leak with oil flowing out where trans joins engine. You should crawl under vehicle and look directly up from oil leak, If inside garage use a newpaper to catch current drip.
Gassy oil can be leaking fuel injector draining into oil pan. Sometimes dirty fuel injector will stay open and fuel pressure will continue to drain into motor after vehicle is off. Sometimes stuff like seafoam will clean injectors.
Nov 09, 2017 | 2003 Ford Expedition
The top freezer compartment drain hole ices over and freezes up and then the moisture goes down into the refrigerator and accumulates under the crisper drawers. This is a frost free fridge.
Hi and welcome to FixYa. I am Kelly.
The compartment drain is most likely clogged somewhere other than the funnel in the freezer compartment. Often what happens is the very end of the drain tube in the very bottom of the unit at the drip pan gets coated with lint and gunk. It then dries off and makes the perfect PLUG. Here is what I recommend you do:
1. Unplug the unit and do a manual defrost by directing an external fan into the freezer compartment for just over 2 hours with the contents removed. It takes this long because the water in the drain funnel acts as an ice insulator and you have to get it above 33F.
2. While the manual defrost is in progress remove the fiberboard rear panel and access the drip pan. Make sure the very end of the compartment drain is cleaned off. Clean out the drip pan also. These can get very nasty.
3. At the end of the 2 hour manual defrosting period... use a vacuum on exhaust and direct air into the RND of the compartment drain tube. Your trying to float out and debris from the drain funnel in the freezer compartment. Have someone listen for air-flow in the freezer from the ddrain funnel if possible.
4. Reinstall the rear cover and return the unit to normal service.
This works most of the time. However if there is a pinch or a kink in the compartment drain tube somewhere the problem can easily repeat.
Thanks for choosing FixYa,
Kelly
Jul 02, 2011 | Refrigerators
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
How to and what tools are nessacery to change oil
oil catch pan hydraulic cat and ratchet with metric sockets adjustable filter rachet lift car front get on under with oil pan rachets and on the motors side of the car you'll find a bolt on the crank pan just a lonley screw on the bottom of a pan close to where your under loosen screw first then put oil pan under try and loosen screw slowly so when it lets go you can cntrol the flow a little so the oil pan can be put in the proper place to catch the oil let it empty till there is nothing but droplets return screw and tighten back on do not over do it the treads on the pan can be harmed if you over tighten then locate filter put oild pan under filter loosen and the same way as the screw do with the fiter . Before putting in new filter on put some fresh oil on the rubber ring and inside just a little so it goes on smooth your finished under the car now go up top hood open you can put car down by now find oil cap and fill in oil
Apr 03, 2010 | 2002 Toyota Camry
Dripping fuel from the bottom of the burner its a af15 beckett oil burner
No, you should call a person that can service oil burners. Either the nozzle is bad and oil is dripping into the burner tube and running down or the nozzle is loose and the oil is running out from the threads of the nozzle. Either way the nozzle should be changed and the burner retuned with a combustion analyser..
heatman101
Mar 27, 2010 | Heating & Cooling
Car runs fine for about ten minutes. Then something from the lower side of driver side motor seems to be smoking or catching on fire? we had a mechanic say it was a blower motor? there is no blower down...
need to know what vehicle u have. is it the 91 lumina in ur pic i see? if it is, ..is it an oil smell? if it is, check the rear valve cover, see if its leaking onto the exhaust manifold--very common problem..hope that helps you out !!
Jul 08, 2009 | 1991 Chevrolet Lumina
Back burner caught fire
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Jun 17, 2009 | Kitchen Ranges
Frymaster Dean MJ45EMSD Deep Fryer Logo
120 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
