Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Crush to cube
My freezer is stuck on crushed ice and won't switch to cube. How can I correct this?
I have this problem aswell. I correct it by reaching up and removing the 1-2 cubes with my finger that were stuck in the area where the cubes drop into the glass. Seems the sensor is blocked and cannot switch back.
Posted on Aug 22, 2008
SOURCE:
My maytag refrigerator crushed ice will not switch back to cubes
Try replacing the ice bucket. That has the teeth and gears that crush the ice up. It could be stuck. If not then there's a solenoid in the back of the freezer that switches the ice bucket from cubed to crushed. You'll see the rod in the ice bucket slides into a square hole that moves up and down. That's it there.
Aug 25, 2016 | Maytag Refrigerators
Ice maker problems
Not sure which refrigerator you have but on mine when you select cubes there is a baffle that is pulled out of the way making the opening large enough to allow full sized cubes to pass. When you select crushed the baffel is left in place forcing the ice to pass through the crushing section. My guess is they are all probably about the same. So either the baffel peice on yours is missing, electrically stuck. Hard to say for certain with out seeing it.
Dec 27, 2011 | Frigidaire Refrigerators
My ice maker is crushing the ice despite the fact that I have it set on cube. I have dumped the ice out of the catch tray twice and made sure that the dispenser is not blocked, but it still continues to...
the bottom of the tray has a rod attached to it that controls a flapper that opens up to allow the ice to pass thru without hitting the cutter or crush blades. this rod goes into a housing at the back of the freezer that has a solenoid switch that activates it to open it up. check to make sure all of these items are free of ice and in their proper position and or not broken. if this all looks good then you may have a bad solenoid switch.
May 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice maker stuck on crush, continues to crush ice when cube button is pushed.
Remove ice bucket,check solonoid on back wall behind bucket may be stuck in up position pull down and recheck dispencer.
Jul 14, 2009 | Frigidaire GLHS66EE Side by Side...
LG fridge freezer GR-L207QVJA. The ice dispenser gives a choice of crushed ice or ice cubes, but has stopped dispensing ice cubes and gives crushed ice on both settings.
Jul 01, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
99 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
