Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
JVC Model AV-48P575 Green/Yellow Screen
Over the last 2 months i have noticed that the colour on my TV has been becoming progressively a green/yellow colour where there should be white. After opening up the back i notice the the blue (i dont want to get this wrong) bulb is dim but not out, is there anything i can do or just have it done professionally. Thanks I think I have a screen peoblem, I have a brown cloud because I have used the tv on a regular setting. Whn I use the wide screen ( cinnema setting ) the screen is perfect 6" on each end, and a brown color where the regular screen has been used.The televison has been flawless except for this problem. Can the screen be replaced easily,? And, Where do I buy one ?
    Master:
  • 623 Answers
Sir,what you need is a tube replacement...thank you
Posted on Aug 19, 2008
    Master:
  • 521 Answers
Technical help is much advisable.
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Certainly, I can help you. I would recommend going to the following link and getting the service manual so you can see first hand disassemble instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new screen. here is the link.
http://servicemanuals.vstore.ca/
Good luck...
JVC Model No. AV-48P575. Picture goes all distorted after it's been on awhile, then a bit later it goes back then distorted again. Can someone please help
Ur tv are developing a problems call convergence,it dying.The convergence board the 2 STK convergence ICS,and some or all it resistors are dying.These parts are must be changed to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
May 21, 2010 | JVC AV-48P575 48" Rear Projection...
Need downloadable manual
Click HERE to download required instruction manual of JVC AV-48P575
Thanks.
Aug 26, 2009 | JVC AV-48P575 48" Rear Projection...
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
No sound on JVC AV-48P575 48 inch rear projection TV
Try going into the menu and find something called, "center channel input." If it is on, the sound will not work. Turn it off, and the sound should be restored.
Mar 23, 2008 | JVC AV-48P575 48" Rear Projection...
i would check the red color first it sounds like your loosing red
Feb 22, 2008 | JVC AV-48P575 48" Rear Projection...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
