Question about Gateway FPD2185W 21 in. LCD Television
Doesn't rotate and doesn't go into high resolution
When I rotate it nothing happens and I can't go above 1024x768. EzTune 1.54 is running and this computer is a very late model Compaq laptop (A931NR) with an intel graphics chipset. All the buttons on EzTune are grayed out except options and help. In other words, the monitor is not communicating back to the graphics card or EzTune just thinks it's not. This has happened on every computer I ever used it with - wish I hadn't bought this monitor.
Anyone else having this problem? Solution?
Have you installed the software for the monitor and the drivers
Posted on Aug 20, 2008
My screen just goes white,I have to press back to get screen on again
Control panel/display Adjust resolution
Change the resolution 1024X768 see if that helps if it does keep going up until it turns white again then lower until it doesn"t
Terry
Jan 07, 2015 | Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
System Reference
it might be the resolution or the frequency
check your monitor compatible frequency and resolution,try 60 Hz and 1024x768 resolution
just comment this solution if it doesn't work and give me more details
Aug 23, 2012 | Apple Computers & Internet
My hd20 has a power-icon light of amber, when power button is pushed it goes to flashing green and it doesn't turn on, just flashes green
Have you tried decreasing the resolution of the computer?
When the resolution is too high for the projector, something similar to your description happens.
Oct 23, 2011 | Optoma HD20 DLP Projector
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
I cannot connect my computer to my LG flatscreen with an AVG. When I use a different computer (thinkpad), an RGB portal opens, while with emachines, nothing at all happens. The computer detects the...
If the resolution on your computer is set too high you will not get any display on the TV. Try a lower resolution.
Please rate my solution to show your appreciation!
For more tips visit my blog at http://thegeektweet.wordpress.com
Jun 04, 2011 | Computers & Internet
Windows XP SP3 does not recognize the screen size of 1440x900, or any resolution other than 1024x768/800x600 It's a Westinghouse L1975NW, running off an Intel 945 Express Chipset
Problem might be with your graphics drivers
Confirm by following process
Right click on my computer and then click on Manage.
then Choose device manager from left panel of the window
then list of hardware will appear.
if there is exclamatory mark over your graphics drivers then right click on it and then click on update device software
if it doesn't work then install it from your drivers disk, you got it with your motherboard.
May 17, 2011 | Westinghouse L1975NW Monitor
Hi, i own compaq presario CQ42 369TU laptop, how do i increase my screen resolution from 1024x768 to 1280x1024 or higher ?
For Windows XP...
1.
Open Display in Control Panel.
2.
On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3.
When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4.
Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
If you cannot set it any higher than 1024x768 and you have already installed the video drivers, that is as high as it can go for your hardware.
May 04, 2011 | Compaq Presario Notebook
Dear sir , i have an intex branded desktop with 17' TFT monitor . i m using windows XP in this system . sir today i increase the resolution of visual from XP and just after that my monitor gives an error...
Obviously the graphics card is not capable of supporting the resolution you have set so it go's blank.
Although you can set the resolution via the computer the system will not change it back when you save that setting even though you see nothing, the computer doesn’t know you can’t see anything.
You need to go into the monitors menu (a button on the monitor front panel) and set it back to a supported resolution or default.
Start at 600x800.
Once you see an image on the monitor right click the desktop go to properties then settings and slid the screen resolution bar to the right to a resolution that suits you don’t go to high or you will get the same problem.
1024x768 would probably suit you.
Hope this helps.
Sep 12, 2010 | Computers & Internet
Monitor display squashed at edges
check your video card for loose connections
Apr 02, 2010 | Computers & Internet
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
121 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
