Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46A02UC-21 Won't Fill and Drain Runs Continually. Original presentation of problem was that it wouldn't drain. Discovered that Garbage Disposal had plugged drain line. After clearing Drain Line, now drains fine but the drain pump runs continuously and it never fills with water. Have done the Cancel, Power Off routine however, even after that, drain pump runs continually.
  • tahconderoga Sep 08, 2008
    I am reading your postings and we are having the same problem. It started the same way by not draining, flooded the kitchen, etc. Unclogged everything (we think) but now will not fill with water. "Have done the Cancel, Power Off routine however, even after that,
    drain pump runs continually."- how do I do this? Also you say "float
    switch is in the flood position and the drain pump is running..
    there is water under the dishwasher or that switch is stuck up.."
    where is this switch? Model#SHU43C06C/14
  • dellsilv Sep 09, 2008
    I have the same problem. I filled my dishwasher and ran it. Meanwhile my garbage dispoal area was filling up with dirty water (i think from the dishwasher) than suddenly my dishwasher was leaking. Obviously something was clogged. Eventually the clog was clear and Now i am trying to run the dishwasher again. Unfortunately it hums or trys to drain but there is no water or cleaning/rinsing action go on inside the washer.
    What should be done?????????????????????????????????????
  • 725 Answers
Float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My Bosch dishwasher has had a problem since we had it installed. It smells like garbage after sitting for a few hours. This problem is there whether it has been run or not. Water is always standing in...
Was the drain tube that hooks into the sink drain passed over the partition between the sink area and washer area or through a low-level hole. If through a low-level hole, try rerouting the tube over the partition. This forms a 'trap area' to isolate the sink drain from the washer pump area. Hope this helps!
Sep 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Will not fill. Drain pump runs all the time.
Sounds like flood switch has been activated. They have a float in the base of machine, which will activate drain pump if a leak has occurred. Unplug from power- remove right hand side panel, check to see if any water in base. If so, leak has occurred. Clear water from base and test run to locate leak
Aug 08, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
The water is going out the drain and cannot fill up the tub.
Check out the height of your drain. If the drain is too low, the water will drain right out of the tub. Check out the attached photo. Hope this helped and best wishes.
Aug 02, 2009 | Roper RAS8445KQ Top Load Washer
Bosch dishwasher continues to run (Model SHX46A02UC)
This is too common a problem with these units. I have written a guide to help folks out with it. Find it here.
Jul 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Bosch Dishwasher Drain problem
check no blockage in the spigot in the garbage disposal and also that fat has not congealed in the drain hose
Nov 10, 2008 | Dishwashers
Bosch built in dishwasher model # SHX46A02UC
sounds as tho you have a foreign object stuck in the drain pump. only solution is to remove drain pump and check
Jun 24, 2008 | Bosch Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
764 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
