Question about Nokia N95 Cellular Phone
9 button is acting weird.
Everytime i go to press the nine button when dialling a phone number it clears the screen and when i type a message and try to type a letter from the nine button it cancels out of the message and goes back to the main screen. can anyone tell me how to fix it, it is so annoying trying to type messages without using the nine button.
  • rotorboy Aug 19, 2008
    i don't think so. I've tried setting it back to factory settings and it didn't fix it. I haven't dropped the phone or damged it in any way. I have a custom theme on the phone but its been on it for ages before it started playing up.
    Master:
  • 521 Answers
There is 100% some short tracking in the circuit of that particular button.it may also because of some dust collected inside on the circuit of that button.or it may due to moisture.if due to moisture or dust you your self can repair it by cleaning and and blowling the circuit through hair dryer for two minutes.but if because of circuit short get it repaired urgently because if you will use in that condition for some more time it will damage some more buttons and at last whole unit will be not useful.it wiil not cost you much for that.please rate the solution if helped by it as there is not a problem except this in your device.thanks.bye. keep me updated.
Posted on Aug 19, 2008
    Master:
  • 623 Answers
Try cleaning insides of keypads...
press nine button with small srewdriver just to make sure
    Genius:
  • 1,011 Answers
Dear,
was it happened without doing/changing any settings..
regards,
  • 1 more comment
  • SALMAN NASEER Aug 19, 2008
    by the way here is a great link for you regardsing service..
    http://www.eserviceinfo.com/downloadsm/2...
    hope it will work. if not then tell me im here to help for the curement of the problem..
    ok,
    after cleaning the keypad with a soft cloth, leave the battery away from phone and after some couple of minutes. try again moreover switch on you phone without memory card and then do a default to it ..
    hope u will get +ve results..
    regards,
    did u get anything from the link above mentioned.
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
Tip
Ericsson CODES DESCRIPTIONS
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
Shortcuts:
Save a Missed Call into your phone directory Scroll to "Missed Call", press "Yes" to display the required number. Press any number (i.e. 0 to 9), then press "clear" once to clear that number, then press & hold "<" until you see "Store". Press "Yes"
Hide your number when calling when you don't want the other party to know your number) After dialling the required number & before pressing "Yes", press ">" twice to choose "Hide Id?" & then press "Yes". Also works for pre-programmed & last dialled numbers just press "No" & wait for the number to appear on the screen first then follow same procedure
Check you battery level when phone is off Press "No" quickly one time & wait for the battery meter to show up!
Save a number into your phone memory (not SIM card) Follow normal procedures to store a phone number. When prompted to set a storage position, press "#" once & key in desired location, or press "#" twice for next available position
Call a phone number from SMS message You can call from within a SMS message if the phone number is written in it. Just scroll the message until the phone number appears on the display, then press "Yes" to call
on Aug 30, 2009 | Nokia 9500 Communicator
Nokia C6-01 How do I delete single dialled or received calls from the Log? I can delete from the dialled screen but the call remains in the Log.
Hello Sinyoro,
In the Call Log eg. Dialed Numbers, highlight the number/contact you want to delete, press "Option" and then select "Delete", this will delete only the selected entry. Make sure you don't press the "Delete All".
Hope this helps.
Thanks.
Jan 01, 2018 | Cell Phones
Hey there, I own a LG Xenon (LG GR500FD) and my screen is acting real weird... when i touch the screen, the screen "sees" my finger higher on the screen than the real position......
The phone should still function fine with the keypad open.
So type in your code, then use the arrow keys to select yes and hit enter...
Mar 29, 2011 | LG Xenon GR500 Cell Phone
Hi, the incoming message red light is staying on. However all new incoming messages have been cleared. How do I fix this ?? Thank you DOnna
2 ways to clear this (most likely someone tried to intercom you and pressed the message button on accident instead of hanging up):
way #1:
1) press the "MESSAGE" button
2) on the screen it will display who turned on your message light
3) press the "CLEAR" button (third button from the left directly under the screen)
way #2:
1) press "INTERCOM"
2) dial " *700 " then your extension number (you will hear a confirmation tone)
3) hang up
Jan 06, 2011 | Panasonic KX-T7630 Corded Phone
Model no kx-TG7120E is it possible to the rid the last dialing no
Press the redial button (the one you describe).
Press the OK button, it will display "Erase"
Press OK again, it will displa "Erase? Yes, No.
Scroll to Yes and press OK again.
Feb 17, 2009 | Panasonic KX-TG2431 Cordless Phone
My snom 300 is dialling letters instead of numbers how do I fix
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Nov 25, 2008 | Snom 300 IP Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
One touch dialling
to return to it original settings, press prog button then press the button that you want to change, press 0 and enter its original button assignment
Jun 28, 2008 | Panasonic KX-T7730 Corded Phone
Nokia N95 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
