Tv trouble shooting techniques
What is the first step or techniques if the tv has no power
    Sergeant:
    Champion:
  • 236 Answers
Change the TV to another outlet.
check for any blown fuses.(look in manual)
check the TV's lamp.(look in manual)
Posted on Aug 19, 2008
Westinghouse hdtv, model # dw39f1y1 Tv receiving no power when plugged in to a power source
Turn On & Has No Power & No Standby Light Troubleshooting & Repair - YouTube
please search for and view the above youtube video for power trouble shooting techniques. YouTube
Jan 01, 2018 | Westinghouse Televison & Video
Due to electric power problem my 26" samsung LCD TV blown up. Is there any safety measure in the form of fuse or circuit breaker in LCD TV's manufactured by Samsung India
Yes. The TV has a solder in 4.5 amp fuse. BUT most of the time when the power surges it also shorts the Bridge rectifier assy. IF you are not familiar with solder techniques, you will have to replace the power supply board. SHOP jimmy has in stock. Use model number .
Feb 18, 2011 | Samsung LA26A450 26 in. LCD TV
HT DB600 I NEED TO KNOW THE CORRECT PLUGS THAT GO FROM SURROND SYSTEM TO TV
APPLY CABLE CONNECTION ELIMINATIONS TECHNIQUE.
First, make sure the speakers, woofers are connected to the surround unit receptacle area located at rear end of device. Second, make sure the power cable is connected to the surround device at rear end and plugged into external power outlet like an extension cord. Third, the remaining connection ports on the surriound unit are for transfering signals back and forth to TV or DVD, VCR, DVR, player devices. Usually the surround unit may be capable of connections to more than once recorder device causing the prevailence of several remaining ports receptables located at rear of unit. However, first, attempt to acheive connection to display unit like a TV set. if that were successful, the last remaining port wirings would be expected to allow for DVD, VCR, DVR, Media devcie connections. The surround device may not have been acquired with several cable wires to connected to every available home appliance. However, the surround device ports are several at rear area of unit to support several home media player connectivity. If several home player device are required to be connected to the surround system, the cable wiring may have to be acquired from retails to complete the signal sharign and splitting process. Refer to the user guide on step by step instruction on achieving connectivity. Also provided on the user guide are details contributing toward acquirign accessories for the device or performing manufacturers diagnostics.
Jan 22, 2011 | Samsung HT-DB600 System
Hi my mom was using her new processor she got today and she put onions in when she noticed it pureed them and left chunks?
When you are trying to chop things in the magic bullet make sure that you use short pulsing movements, don't just hold it down. This will make things go mushy instead.
This is the advice they give on their website:
http://www.buythebullet.com/
You may be over processing your food by letting your Magic Bullet slip into Lock On Mode (see video demonstration of Lock On Mode) when you should be using the Pulse Technique (see video demonstration of the Pulsing Technique). Please read the Pulse Technique instructions on page 15 of the user manual or follow the steps shown in these video demonstrations and you'll be making perfect chopped onion, salsa and all your favorite textured foods in no time.
Dec 26, 2009 | As Seen On TV Magic Bullet Food Processor
How to program the TV with a new remote
if you do not have the directions. first manually turn on the set. then i find the code button. it may not say the same thing but it will be similar in words. push code, then push tv, then repeatedly push power until the set goes off then find enter(or something similar). this is an automatic code find technique.
Nov 10, 2009 | Sansui HDLCD-4212 LCD TV
Picture is squeezed down to middle with a bright green horizontal
Replace the vertical IC you will need to discharge the flyback and replace the IC it can be done if you know what your doing but there are a lot of youtube videos to show you how this is to be done.
May 25, 2009 | Zenith B27A11Z 27" TV
Cannot get a picture
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then you have a more serious problem, that requires the attention of a TV repairman.
Jul 05, 2008 | Televison & Video
Samsung flat tv has no picture
Try a "hard restart", which simply means unplugging the power cord of the TV , and replugging it 4 hours later. This technique is useful for reprogramming the electronics of the TV. Hope it works for you.
Jun 29, 2008 | Samsung Televison & Video
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Hope this suggestion works for you.
Jun 05, 2008 | Mitsubishi VS-60607 TV
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
