Question about Newpoint (200897) (DHN200897) UPS System
Newpoint battery backup
Electric goes out- and everything shuts off- immediately- no back up at all?
thought it should run battery back up for a few minutes?
    Problem Solver:
  • 15 Answers
Check whether the batterries are ok, if  yes check whether the system is charging.
Posted on Oct 14, 2009
How do you connect 200897 battery, it is no longer working
I just bought a battery (readily available) for $16 and here is how I replaced it, but first, make sure UPS is disconnected from 120 Volt service. (Old battery number SW1233 with F connectors.)
Turn the UPS over and look for 1 tiny screw (even with the "in" telephone wire socket). Remove the screw (turn CCW). Push the button marked push, then slip a steak knife or sharp putty knife into the joint in front of the screw hole. Twist the tool enough to start the battery cover moving backward (to your left).
The battery is upside down. Lift it high enough to grab wires and pull them off the postst.
Verify battery you bought fits the housing. With UPS upside down, place battery on right side with lugs toward the power cable. Push red wire onto red post. Hold the battery upside over UPS. Push black wire onto black post.
Visually ensure the wires both run in their channels (otherwise the battery will not seat and the cover won't slide on.) Push battery into slot until it bottoms.
When the battery is bottomed properly, hold the cover about 2/3's over the battery housing, push it down, then push it toward the screw hole (to your right). If this operation, or the cover jams near the screw hole, check the battery. It must be absolutely bottomed in the slot. The cover won't go on easily even when everything is perfectly aligned.
After the cover is closed and the screw replaced, plug the UPS into a wall socket. The on/off button has a mind of its own, so ignore it. The green light may light and there is one beep. The backup yellow light may blink. The green light may stay solidly on. Pull the cord plug out of the wall. Now the UPS green light may go out and you will hear a ratcheting sound (the UPS is making AC from the 12 Volt battery current). Because you have no device plugged into a "battery-backup" plug, the UPS will shut off automatically in a few minutes.
The last test is to reconnect the plug to the wall service, then plug a monitor, a music system, or something similar into a Battery B/U connector. The green light should light. When the UPS is again unplugged, the yellow light (Backup) flashes and there is a repeating beep. Plug UPS back in. Only the green light will be on. That's it, all done.
I use Newpoint UPS to back up my telephone/modem. During a brownout, SPS powers those units almost 2 hours.
Note: This UPS is not suitable for powering or charging Laptops because the power output is too dirty.
R Hicks
Oct 22, 2013 | Newpoint (200897) (DHN200897) UPS System
Battery Back Up receptacles no longer work
Your battery is either disconnected or failed and must be replaced.
Apr 06, 2010 | Newpoint (200897) (DHN200897) UPS System
How can i get the electrical service map for 200897 surge protector
THANKS FOR YOU PROFESSIONALISM BUT ALREADY WE SOLVE THE PROBLEM THANKS
Nov 11, 2009 | Newpoint (200877) UPS System
The battery backup is beeping intermittently, but the power is not fluctuating. Does the battery backup require a new battery???
If it's more than 3-4 years old chances are the batteries need replacement. Typical lifespans are 3-5 years on most batteries.
Oct 13, 2009 | Newpoint (200897) (DHN200897) UPS System
ONLY 2 MINUTES MAX OF BATTERY BACK-UP TIME BEFORE EVERYTHING SHUT
you can program your power bottom to hibernate, and connect the screen direct without the UPS, so you get more time...then when the electricity goes off, without seeing the screen just push the power bottom to hibernate.
Dec 03, 2008 | Minuteman Office Plus 500 UPS System
Shuts off when power goes out
replace the battery here is a battery from a decent seller http://www.refurbups.com/s.nl/it.A/id.9156/.f there are 5 phillips screws in the bottom, flip it back over and pull th lid off carefully, pull out the battery wires (they are snug) and put in the new battery and put the screws back in.
Jul 10, 2008 | Energizer ER-HM650 UPS System
Battery appears charged, but computer will only run when plugged in
does your battery have one of those charge indicator panels on bottom?
also, it's possible that the connection from battery to the internals is shot..if that's the case, then you're looking at a major motherboard swap
May 15, 2008 | Lenovo 3000 V100 Notebook
No back-up
YOur UPs is defective. Check the battery. DId you connect it when you first set it up?
Hope this helps.
Oct 21, 2007 | Newpoint (200897) (DHN200897) UPS System
Newpoint (200897) (DHN200897) UPS System Logo
596 people viewed this question
Top Newpoint Computers & Internet Experts
David Payne
David Payne
Are you a Newpoint Computer and Internet Expert? Answer questions, earn points and help others
