Broken ihome At first my ihome speakers were fine, but then they started buzzing, and eventually went dead. I unscrewed everything and a small green square with blue cylinders on it didn't look right, so i tried to fix it, and it worked for a few minutes, but went dead again. I also tried putting in new batteries, but that didn't work. HELP!!!!
techman
  • 3130 Answers
SOURCE: Center, surround speakers not working. "Can't Use" message for DSP.
Sounds like the old stuck button thing after a move??? What i mean it go over all the push buttons and maybe you will find one that is not pushing in and returning??? If alls ok then you should check the obvious like bent shafts or balance controls ect. ay have jogged something inside and you will need to see a pro to assit you unless you know how to trouble shoot solid state electronics?? These units have no real serviceable parts inside. Check with your owners manual for the sevicer nearest you. If they are not listed call the service # or try 1-800-289-AIWA . good luck
Posted on Jun 06, 2006
SOURCE: Denon 2902 No Sound
REPLACE MUTING TRANSISTORS IN DSP PANEL
Posted on Sep 05, 2007
The Joat
  • 81 Answers
SOURCE: Sound card broken? No normal sound and a constant buzz...
Sounds like you tried everything possible. Based on what you have stated that you tried already I would agree with your diagnosis of a bad sound card.
If this was my Laptop I would be looking for a nice set of USB speakers and Microphone or a headset.
You can either keep the speakers turned down or you may be able to disable the onboard sound through a BIOS setting.
Or even better. Here is a USB sound card with speaker and microphone jacks. Pretty Cheap too.
http://www.wolfcamera.com/product/EP4497467.htm
Posted on Jan 06, 2008
  • 6 Answers
SOURCE: Marantz Sr8500
Check the speakers impedance. it should be greater then 6ohm otherwise you overload the system. Also, if the speaker sytem is rated (in Watts) below the amplifier's power it overloads the amp at higher volumes.
Posted on May 18, 2008
SOURCE: Sound problem with JBL Creature II
I had a problem with the speakers not working properly. The green lights lit, but the amount of sound coming from the speakers compared to that of the sub was much lower.
I decided to take it the speakers apart.
I found that the magnets on the speakers had moved forward slightly in the plastic cage they sat in. I pushed them back as far as they would go, and Hey Presto! working again!
I hope this helps someone!
Posted on Jul 06, 2008
I dropped my ihome speaker in the snow and now it has a buzzing sound. I can still here the music and it's not holding a charge.
For the 20$ they cost, I believe it's not worth to repair it, unless you have a tech in family. So.. 20 $ lost. Buy a new one. They are disposable
Feb 27, 2015 | iHome Audio Players & Recorders
How to take apart
The port was broken on mine also. I looked online and found no help so I decided tear it apart since it was broken anyway. There are 6 phillips head screws located under the speaker cover. The black mesh material is glued down so you have to pry it up and then peel. The backing tore on mine so it will be a challenge to actually remove it without damaging it. Once it is off, you can remove the 6 screws and it will open right up. The charger port is located inside a small black box that is held down by 2 screws. Once I got to the little charging port, I found that it had become separated from the circuit board and couldn't be put back on. Not unless you know how to solder or do circuitry. I figure it isn't repairable.
Dec 27, 2012 | iHome iDM12 Rechargeable Portable...
Volume Problem
batteries are getting old. replace OR the audio has too much bass in it.
Sep 07, 2012 | iHome Portable Sport Case Camo Green...
I have a Kenmore Dryer from Sears Model 97292100. It was working fine for several loads the other day, but when I went out to get the next load out, it had not dried completely. I set it to run again, but...
Is the belt tight around drum. If yes, then there is a tripable thermistor in the heat tube. Small button on it that slight push on it resets device. If belt is loose but not broken, then it is off the tensioner b
May 05, 2017 | Dryers
463 people viewed this question
 Grubhead
Grubhead
