Cell Phones Logo
Posted on Jun 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone will only play default ring tone for all incoming calls...can not customize ringtones for individual callers
dheeraj jain
Level 2:
New Friend:
  • Expert 33 Answers
  • Posted on Jun 11, 2011
dheeraj  jain
Expert
Level 2:
New Friend:
Answers
33
Questions
0
Helped
4465
Points
109
This problem is software related.
1st u do restore factory setting. if not sucess then u have to do reflash ur phone.
Lg extravert
You have to set up a ringtone for texts and also one for calls.
Jul 20, 2014 • Cell Phones
3answers
Incoming caller ring
Here is the link to the user manual if you need it. http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/30277_E815EnglishUserGuide.pdf Unfortunately what callers hear is dependent on the phone they are calling from, not on your phone. You could concievably send them a mutimedia message when they call, but there is no way to automate this, and it would probably be too much trouble and expense to bother. Wait a year or two, and it may well be that manufacturers start including this feature - it would require a slight modification of the communications protocols on the cell networks, but it probably would be popular. Good idea. Hope this helps :)
2answers
Changing ring tones
first go to the song second click on set a list will be shown third click on caller ringtone after that you will assign song to individual
1helpful
How do i change the ringtone callers hear when they contact my htc wildfire
Thanks for visiting FixYa!
In most cases, the ring tone callers hear (incoming ring tone) is controlled by your cellular service provider.
Try this first: (On the Internet) Sign-in to your cellular account. On your account page, look for a link that directs you to your incoming ring tones (or similar). There, you can change your incoming ring tone.
If you're unable to do that, contact your cellular provider's Customer Support. They can assist you in changing your incoming ring tone.
1helpful
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Downloaded a ring tone with the memory card but when i load it on the phone it will only play as music, can't set it as a ringtone.
Hi friend,
Could you tell me if your cell phone can support the function?
You can check like the following:user profile-General-Customize-Tone setup-Incoming call,then you can see many ringtones in it,Could you see the icon"empty"?If so,you can set the ringtone you downloaded as the ring tone of incoming call.You just need to find the ring tone you downloaded,and transmit it to the "user profile".
But if there doesn't have any "empty" icon,I am afraid that you cannot set it.But you can try to cancel some ringtones ,and replace them by the ringtones you downloaded.
You can get much detailed information in the website:www.1010store.com
2answers
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
Ring tones v3xx
With Motorola, they made the software so that when you have a call and an sms from a person that has a custom ring tone, it will ring like that both ways. Thats a limitation in the firmware with no way around it. And yes, you can either call your carrier to block it by default on the network itself, or you can go to into the phone settings and toggle a menue called send caller id, and click off
Ringtone wont play
with the phone closed, goto tools, voice commands....click on settings in the lower right.......scroll down to call alert.......change to ring only or caller id+ring....on the env that should solve your problem
Phone wont play ringtone with incoming call eventhough one is selected will spell out number calli
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
