Question about KitchenAid KGST307 Gas Kitchen Range
Inside oven door glass broken - KitchenAid KGST307 Gas Kitchen Range
I have a Kitchenaide Gas Range. KGST307 Inside glass on the oven door broke.. need to replace. is it easy to do? going to order glass online.. I did call some local repair people.. looking at a $200.00 to $250.00 bill to fix... NOWAY............ I can buy the glass and do it myself... Need some help if it can be done..... Any Help is COOL!! Thanks TED... 425-549-0150 WA. 98014
Posted on Dec 13, 2008
Tip
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at Fixya.com about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 22, 2010 | Ovens
The oven door inside glass has shattered and I was wondering if and how could I replace the inside glass pannel?
Hi.
Yes it is normally possible to replace broken door glass.
Try the following site for some very helpful information
WWW.YOUTUBE.CO.UK
In the search box enter--REPLACING OVEN DOOR GLASS.
Ther are several videos on how to repair oven doors.
Jan 03, 2011 | Ovens
Kelvinator F36 oven door glass measurements
you have to get high temp glass or it will shatter
May 24, 2010 | Ovens
Inside oven door glass broken Can I replace broken inner oven glass myself? I broke it today and need some help.
I would guess that you could not. It is a safety glass and has a special gasket material. Although you may be able to buy the door as cheap or cheaper than just the glass plus the install. Hope this helps. Have a great day.
Apr 17, 2009 | KitchenAid KGSC308LSS Gas Kitchen Range
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Jan 01, 2009 | Zanussi ZBQ365 Electric Single Oven
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
KitchenAid KGST307 Gas Kitchen Range Logo
347 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
