I have a 400 watt speaker and the board in not working and the the speakers and everything else is working good but i think that it the board inside the speaker.
  • demet_javier Jan 23, 2009
    my 400 watts doesnt work well,tweeters have sounds but the wooper dont have
    Problem Solver:
  • 15 Answers
The board that you are talking about is the crossover, does any of the speaker work the woofer or tweeter or midrange drivers? If the woofer does not work then take out the woofer and take the wires that attach to the speaker on the back and hook them directly to the speaker that you took out if it plays you need to replace the crossover in the speaker, this should be easy, just call the company that makes the speaker and order a new crossover, you can do this also with the speaker if there is no sound when you hook it up direct.
Posted on Aug 19, 2008
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
What are the specifications for audiobahn a2200hcx amplifier
The specs are as follows:
RMS Power Rating:
200 watts x 2 chan. @ 4 ohms
400 watts x 2 chan. @ 2 ohms
800 watts x 2 chan. @ 1 ohm
• Bridged:
400 watts x 1 chan. @ 4 ohms
800 watts x 1 chan. @ 2 ohms
1600 watts x 1 chan. @ 1 ohm
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meters Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable High-Pass Crossover: 50-750Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
THD: 0.05%
Channel Separation: 50dB
Apr 15, 2011 | Car Audio & Video
What is the best suited power amp for the Peavey PV14 mixer board?
that depends on your speakers, not the mixer. the amp should be matched to the speakers, in watts and in ohmage. for example, 400 watt, 8 ohm speakers should get an amp that runs at 350-500 watts at 8 ohms.
Apr 22, 2010 | Peavey Pv 2600 Power Amplifier
I have a pair of bose 901 speakers with an onkyo 100 watt amp. the amp is going out i think what is a good replacement?
My $.02: anything strong and clean. I'm partial to Carver amps and have run mine with double M-440 cubes bridged to 400 watts per speaker at one time. Right now I'm pushing them with a single Carver M-100T (100 wpc) and it sounds as good without being dangerous.
Feb 07, 2010 | Bose 901 VI Main / Stereo Speaker
What Kind Of Car Amplifier Do I Need?
A kicker amp with full range out put that has a switch for the range you most like. do not go over 400 watts rms or the tweeters will blow.
Jul 24, 2009 | Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Need amp
Hi and welcome to FixYa,
It would be safe to use an amplifier slightly lower than the maximum rating of the speaker. In this particular case, 350 watts or lower would be just about right for each. If you are wiring the 2 subs in parallel and powering them with a single channel amp, then a 700 watt bridged would also work.
Good luck and thank you for using FixYa.
Apr 09, 2009 | Hitron 2 12in Subwoofers loaded in...
Latest model surround receiver for bose 901 speakers VI
I can think of no reason any amp pushing 120 watts would not work with 901-VI's. They're very efficent and will probably play louder and cleaner than you would ever need. As I recall, my old series IV's have no maximum amplifier rating specified, but I did blow up a bridged Carver M-400 Cube (pushing 400 watts to one speaker with a DVD-Audio of Yes - Fragile cranked dangerously high) with them. I'm convinced my speakers are indestructible in any home application.
Keep in mind that whatever you decide to use as your control/amplifier section, a pair of 901's need a dedicated stereo amplifier. I suspect you're thinking surround sound so a receiver with separable preamp/amp channels, due to the Activbe EQ, would be needed and as far as I know they don't exist. A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. 120 clean watts is good. I'm using only 110W for mine.
A Carver M-200 is a fine, efficient amplifier that would have you cooking just fine (2x100W).
Mar 20, 2009 | Bose 901 VI Main / Stereo Speaker
Peavey amp
You could also use speakers rated less than 400 RMS provided you dont crank the volume knobs all the way up.
I think the CS400 is 200 Watts RMS per channel into 8 ohms
400 watts bridged
Here's the manual. You'll need acrobat to open it.
http://www.peavey.com/assets/literature/manuals/80300990.pdf
Dec 05, 2008 | Peavey CS 1400 Amplifier
Speakers
400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
60 people viewed this question
 Grubhead
Grubhead
