Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Unable to select application on scanner menu
If this is the problem, how do I get a proper power supply to it.
The problem seems to be that I do not get the option to select application
Can you please clarify?
Thanks
    Scholar:
  • 96 Answers
In order to get this option you need to connect the printer to the computer and set it up through the home center. Only then will you be able to choose an application as the place to scan to.
Posted on Aug 26, 2008
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
We would like to connect our Epson GT-15000 scanner to our new Imac 29inch. Although we do have the scanner connected to a G5, we seem not to have any sfotware for Mac, only the Windows CD. Where can we...
No additional drivers are necessary. Your Epson GT-15000 is listed in "Printer and Scanner software available for download,"http://support.apple.com/kb/HT3669 .
To add your scanner, simply plug it in. If it does not appear in Apple Menu > System Preferences > Print & Scan, you may need to run Software Update (also from the Apple Menu, second item down), and then click the plus ( + ) button in the lower-left of Print & Scan, select your scanner, and then add the printer.
The default scanning application in OS X is Image Capture. After completing the above steps, open Applications > Image Capture and you should see your scanner listed on the left.
Aug 28, 2013 | Epson Office Equipment & Supplies
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Downloaded an application won't work properly So I want to delete it . How do you delete apps you no longer want
Please select "uninstall" or similar option from the menu containing the program oprtions. If it is not found, go to control panel -> Add/Remove Programs and select the program and click remove. The application will be removed.
Webmaster
www.incomeinnet.com
(An online encycopedia on earning money through internet legally)
Jun 14, 2011 | Computers & Internet
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
I have a dell dimension E521 and it no longer powers up. When turned on rather than booting it up the light just flashes orange. The advanced troubleshooting says # If the power light is blinking amber,...
You are correct. According to the Power LED it diagnoses this as:
The power supply is receiving power from the source but is unable to properly distribute it to the components. Reseat all power connections to the system board.
It's either the power supply or the motherboard. Power supplies run anywhere from 50 to 100 dollars. Motherboards for the Dell can run anywhere from 200 to 300 dollars plus labor. Also check your USB ports to see if any are damaged. They can short out your power supply if broken.
Jan 09, 2011 | Dell Dimension E521 PC Desktop
Hi how are you? i am trying to scan by graduation pictures to my computer but it was unable to do that i dont know why it was woring perfectly fine.. it says INIT UNABLE HELP ME
if ur using windows xp then u can scan ur pictures from my computer. if ur scanner is properly installed then u can find scanner or camera device on ur my computer screen. u jst need to right click on that select 'get picture from scanner or camera wizard' . here u will get the scanning option.
& if u having widows vista or windows 7 then u can scan ur pictures from 'paint'. u will find scanner or camera option in file menu.
Dec 20, 2010 | Brother Office Equipment & Supplies
I have a microtek scanner Scanmaker 3840. i am unable to use it with windows 7. kindly assist
open your device manager in control panal
attach your scanner with computer and power on
look at imaging device
double click the usb scanner or right clik the scanner itom
select update driver
select brows my compurer for driver software install driver manually
insert your software driver cd in cd rom
search for driver software in this location brows and select cd or dvd rom drive
select tickmark at included subfolders
then click at next button
auotmatic install your driver
then your scanner is work with device and printer folder
you also instass scanwizard software form your cd and scanner work properly.
Oct 12, 2010 | Microtek scanmaker 3840
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
May 19, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
21 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
