Question about Tefal Irons
Tefal express iron cleaning
Spitting out brown through steam holes, need to clean but the descaler i have bought advises not to use on tefal, what do I need to do to clean and how do i access the boiler compartment.
  • Anonymous Mar 27, 2014
    I have lost my manual and can't remember how to descale the iron
Thankfully I was able to clean the boiler compartment, by unscrewing the large bolt on the boiler, cleaned with water only, loads of brown yuck came out, It would then not allow me to use the steamer, Waited until the next morning tried again and working brilliantly again.
Jopey
Posted on Aug 23, 2008
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
How do I clean the water reservoir in my T-FAL Avantis 90 iron. When I use the iron hard particles come out of the steam holes.
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 23, 2011 | Tefal Avantis 90 Iron
I need to know how to descale my iron
heatman101
Mar 13, 2011 | Tefal Aquaspeed 155 Iron with Auto...
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 | Irons
My tefal express 2941 steams constantly when switched on and cannot be stopped, please advise?
Fill the iron with 50/50 water and vinegar and let it steam for as long as it will. This will clean out the iron thoroughly, the green light will stop flashing and it will go back to normal. Then remember to clean your iron on a regular basis. Mine did!! Found this solution on another site
Feb 20, 2010 | Tefal Irons
Why does my Tefal Pro express stain my ironing with brown marks and scale, I fill the tank with softened household water, but I still get a sudden gush of brown scale water. We live in a very hard water...
Its a real pain, but use only distilled water.
Fill your iron with white vinegar and let it steam until empty.. face down on a towel on lowest steam setting.
Nov 26, 2009 | Tefal Irons
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
How to use the self clean feature on a tefal steam iron
I cleaned mine with alcohol and clean terry cloth. Took some work but it eventually got clean.
Dec 24, 2008 | Irons
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Irons Logo
1,163 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
