Canon i950 InkJet Photo Printer
Problem for Canon i950 InkJet Photo Printer
Canon i950 Print Problem!
By man1 - usenet poster
Apologies if this has been asked before.
My printer has suddenly started giving the sequence of seven organge light
flashes which manual states 'contact a canon service representative'.
Unable to print as it seems to be having print head problems.
Can anyone explain what is happening and what I maybe able to do
Thanks
Bob
Best Solution
posted on Aug 11, 2005
Very Helpful)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
Did you try the reset sequence with the print head removed?
Try to clean the contacts on the print head with an eraser.
That is what fixed the S9000 I worked on.
If the power button doesn't power off the printer just pull the power
plug.
If after all that fails then I think you have a bad print head,  or
the logic board in the printer is bad.
It would be cheaper to get a new printer than to have your printer
repaired.
Was this helpful?
Yes
No
Solution #2
Very Helpful)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
You should be able to see the error codes on your computer. Make sure that
the i950 is attached to the computer and that both the printer and computer
are turned on. Open the printer status monitor. Assuming that you are using
Windows XP, you can start the printer status monitor by selecting
Start->Printers and Faxes. Then right click on your i950 printer icon and
select Properties. When the Properties window opens, select the Maintenance
tab and down in the right hand corner you will see a button labeled Start
Status Monitor. The error code(s) and some sort of description should show
in the Status Monitor window according to Canon's description in the Service
manual.
Good luck,
Blitzko
The Status Monitor should display
Was this helpful?
Yes
No
Solution #3
Helpful)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
I fixed a Canon S9000 printer that was doing the same thing as yours.
Try this:
1. Hold down the resume button while powering on, continue to hold the
power button on untill the lite is steady green.
2. After the light is steady green release the resume button and press
it twice (the light will turn orange and then after the head moves
back and forth and stops moving the light will become steady green.
3. After you get the steady green press the resume button four (4)
times (the light will turn orange, green, orange and green again.
4. after the 4 clicks on the resume button turn off the printer. It
may take as many as three clicks or pulling the power to get the
printer to turn off.
If the above procedure doesn't work remove the print head and try the
sequence again.
If you succede replace the printe head and the printer should be
alright.
Was this helpful?
Yes
No
Solution #4
Helpful)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
From the i950 service manual it states that seven (7) flashes of the orange
LED indicates error codes 1403, 1405 or 1485 which is described further as a
"cartridge error". The cure is to replace the head, if that doesn't work
then the carriage gets replaced and if that doesn't work the logic board
gets replaced. The error code can be displayed on your connected computer
using the Canon status monitor for the i950 (you may have to start it first
in order to see the code). The code number will help Canon to diagnose your
problem more accurately.
If the unit is still under warranty, contact Canon for help. If it isn't
under warranty any longer, you should still contact Canon support as they
may have further diagnosing information. Also, try removing and reseating
the print head. Check to make sure that there is no ink on its contact pads.
If there is, clean the pads with a damp paper towel. My guess is that is
probably the head that has died and not the carriage mechanism or logic
board.
Blitzko
If you find yourself in a hole, then the
first thing you should do is stop digging.
Was this helpful?
Yes
No
Solution #5
Not Rated)
Odud
Rank: Apprentice
Rating: 0%, 0 votes
yes I did
will try this as a last attempt
Power button on/off works fine
preparing myself for that eventuallity
it may come to that
Was this helpful?
Yes
No
Solution #6
Not Rated)
Bomber
Rank: Apprentice
Rating: 0%, 0 votes
Have found a status page headed Canon i950 USBPRN01 but under the printer
status menu it says that "printer is not responding" and "print head is
uknown".  Under the guide menu it says "make sure the printer is connected
correctly, and that the power is turned on (the printer is on-line)"
I have made no changes to the printer at all and has been printing fine for
months.
There is no mention of error codes as I don't seem to be able to get that
far as a result of the seven organge light flashes.
Regards
Bob
Was this helpful?
Yes
No
Solution #7
Not Rated)
Horner
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for your reply.
Can you tell me how I can find the error codes you quoted and what they
individually mean.
Not having much luck finding any info in the user manual.
Bob
Was this helpful?
Yes
No
Solution #8
Not Rated)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
You could try unplugging the printer, then remove and re-seat the print head
carriage, clean the contacts, etc.
Not worth replacing the head IMHO, just go get a new IP4000.
Was this helpful?
Yes
No
Popular Solutions for Canon i950 InkJet Photo
Questions and Unsolved Problems for Canon i950 InkJet Photo
Do you recommend Canon i950 InkJet Photo Printer?
Answer
Answer
I need to replace Logic board and Print head for I 950
Answer
flashes seven amber then one green. What do I do to fix it?
Answer
Black is not printing on my cannon i950 is there a test to run or a way to clean head? all other... (More)
Answer
Hello. My Canon i950 was showing 8 yellow flashes indicating the ink waste tank is getting full. I... (More)
Answer
replaced cartridges and now acts like its printing but nothing comes out on paper
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
