Picture broken up and flickering, ec or av keeps coming up on top left of screen
  • 138 Answers
The problem is the small signal baord that is the video processor.
Posted on Aug 19, 2008
BROKEN SCREEN
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Jan 10, 2013 | Samsung 55" UA55C7000 MULTISYSTEM LED 3D...
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
ninja_freak318@hotmail.com
Jan 22, 2009 | Nintendo DS Lite Console
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
Both Screens Flicker after trying to replace touch screen
I finally solved the flickering problem on my DS (!), after I made my 1st engineering attempt overhaul shell, top screen and broken right hinge.   Was really frustrated about the flicker afterwards, and opened up unit back up too many times to debug (risked damage to cable ribbon everytime!).
Anyway turns out there's 2 hidden screws (location:  inside the battery compartment near where the front 'volume slider' is located) that adjusts the flickering (like how you need to calibrate an LCD monitor from doing same flickering effects) . You'll need a really (really!) small philips (+) screwdriver to do the adjustment.
Open up the battery cover with the VOL label upside down & facing you.  The adjustment screws are recessed deep inside the plastic...a right and left screw.  With the DS turned 'ON' to see the screen (whether you twist your neck to be able to see or have a mirror on the table in front of the DS)....slowly/carefully turn the screws to adjust until you like the clarity.  That's it.   The right screw = bottom screen.  The left screw = top screen.
Now.... on to figuring out how to replace or fix the broken Power toggle switch that I snapped off!  Currently using the toothpick method, but that's getting old!  Any suggestions, I'd appreciate it!
Dec 08, 2007 | Nintendo DS Lite Console
JVC AV-60D501 I belive it is a 60" full screen projection tv for the last few months the picture has been flickering, Flickering like a VHS with bad tracking. It does this in all imputs, from cable imput...
From what you're describing your focus block is probably failing JVC p/n#129P059050. It's probably also very vibration sensitive. They're about $80.00 dollars and they are also interchangeable with the Mitsubishi focus pack p/n#920p016010. Not a difficult repair - we do about 5-6 a month. Real easy in-home repair. Hope this helps. Bill
Jun 18, 2007 | JVC AV-60D501 60" Rear Projection...
AV-60D501
There is a 5, 9 & 12 volt dc regulator on the chassis that could be causing this. Three legged transistors on small heat sinks. I f you look at the chassis from the rear of tv, is two boards.The one on the left has these reg. transistors. Usually the 9v regulator is bad and a 35ufd @ 50v capacitor near it is bad. From the tuner as ground check the third leg on the regulator for less than 9v dc.
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
